F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 2013 F30 Exhaust Tip Removal?
Studio RSR
      09-20-2013, 09:48 AM   #1
jn82
Drives: 2013 BMW 328i Xdrive
I'm a little curious how to remove the exhaust tips on a 2013 F30. Any pictures or helpful hints would be great.
I have used a rubber mallet to push in a pull but no luck. I have read a few forums that said they are removable so I look forward to hearing from you guys. Thanks in advance.
      09-20-2013, 09:58 AM   #2
BavarianFanatic
Too much is never enough
655
Drives: Too Many
Use some muscle and give it a slight twist while pulling.
      09-20-2013, 10:23 AM   #3
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
If you start banging it out with a rubber mallet from under the car, then once it moves a couple cm, you can just pull like hell with a little twist.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      09-20-2013, 12:44 PM   #4
jn82
I tried both and it didn't budge. I feel like I am going to pull the exhaust out. Is there a tool that could help?
      09-20-2013, 02:50 PM   #5
mikew2069
mikew2069's Avatar
413
Just realized you have a 328. Not sure if its different from how the 335 tips are secured.
BM3/H&R/Borla
      09-21-2013, 04:41 PM   #6
KK328
KK328's Avatar
14
Drives: F30 328 gracier silver
I used some WD40 on mine spray some form the inside and give it a couple of minutes then go at it. There are no more tools than what ur already using, what helped me was turning it left and right like your screwing it clock wise and anti clock wise it helps clear the pins and then it slides right out.
There is a post here that has some pictures but can't remember the name I think it was called exhaust tips but not 100% sure try searching it has some pics. Good luck
      09-22-2013, 02:11 PM   #7
Stoofpilot
Naval Aviator
Stoofpilot's Avatar
Drives: 2013 328i
What do you want to replace them with?
Meatball, Lineup, Airspeed means a successful carrier landing-most of the time.
Ah-those were the days!!
      09-22-2013, 05:18 PM   #8
jn82
I'm looking to either Plastidip them or use some hi temp grill paint. Did to on my exhaust on my jeep and it worked great. I tried the wd40 and it still wouldn't budge. Any other ideas?
      09-22-2013, 05:26 PM   #9
mikew2069
mikew2069's Avatar
413
If someone can confirm that they are slide on like the 335 then you just need to bang them off...
BM3/H&R/Borla
      09-22-2013, 05:52 PM   #10
jn82
I believe they are but I'm having trouble banging them out. I have used a mallet and wd40. From what I've seen they are clipped on so they should twist off.
      09-24-2013, 04:53 PM   #11
KK328
KK328's Avatar
14
They are, just put some muscles into it. Check out the below post it has some pictures of the tips and the pins, I got them out on my car exactly like this. It just needs some patience and muscle and they will slide out.
I ended up powder coating mine instead of plast dip cause I wasn't sure if the plasti dip would hold up with the heat
Good luck and update us with progress
http://www.f30post.com/forums/showthread.php?t=840756
      09-24-2013, 06:55 PM   #12
mikew2069
mikew2069's Avatar
413
Just knock the living hell outta them with the mallet. Don't be scared, you won't damage the tip.
BM3/H&R/Borla
      09-25-2013, 05:14 PM   #13
jn82
Thanks for the input, the mallet and some muscle did the trick!
It looks so much better now with the black finish. I went with the dip since it stays in tact up to 200 degrees. Plus I can always peel it and spray it with something permanent. Either way it just required a lot of mallet!
      10-19-2013, 12:43 PM   #14
doubletap
Drives: e36 e39 e53 f30
I just did mine. I used wd 40, mallet and a ramp. I tried it on the ground but I did not get a good angle to knock it loose. I backed it up on the ramp just to knock it loose. Drove it off the ramp for safety reasons. Then pull and twist the heck out of it. whew. replaced it with the gloss black ones from BMW.
f30post
