335is overboost feature
09-16-2013, 05:19 PM | #1 |
Brian335tt
98
Rep 1,227
So this might sound like a stupid question but I was curious if it was possible to get the over boost function that the 335is has where in the first 7 seconds hits 370ft/tq on take off.. I was wondering is this possible to get on a regular 2007 335i coupe? Will the jb4 g5 give me this feeling? Thanks
09-16-2013, 05:28 PM | #2 |
ex deus machina
124
Rep 968
why do you only want the extra boost the first 7 seconds, why not always?
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
09-16-2013, 07:08 PM | #4 | |
Brian335tt
98
Rep 1,227
09-16-2013, 08:14 PM | #6 |
1112
Rep 3,261
Just get a power kit for the other added benefits that a 335is has
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
09-16-2013, 11:45 PM | #7 | |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Power kit is not the same software. The 335is has different base software with a different ignition curve more suitable to higher boost. My 135is runs the PPK-2 power kit as factory standard & stock for stock the 335is is stronger.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
09-17-2013, 05:22 AM | #8 |
Brian335tt
98
Rep 1,227
This is what I'm talking about.. Wouldn't it be possible to use the 335is software on a 335i? Given in practically a factory tune that is probably considered the safest out there
09-17-2013, 06:23 AM | #9 | |
422
Rep 4,499
And the extra cooling features on my 335is, isn't just for the over boost, it also takes care of other things as well.
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
09-17-2013, 08:06 AM | #10 | |
Brian335tt
98
Rep 1,227
09-17-2013, 08:18 AM | #11 |
422
Rep 4,499
The 335is has the better far for the rad (850 watts), the two coolers in both wheel wells, cooling vents, software to control it and Ivo found some more differences but I can't remember what they were. I also had the AR oil cooler on my old 335i and it did make a difference in the temp, but since the 335is has two of them I sold it.
09-17-2013, 08:56 AM | #12 |
86
Rep 1,262
Running a tune isn't bad for the car, as long a s you run a good, well-tested tune. Shiv's car has been tuned since he bought it and now has 700+HP to the wheels, And I think he's over 100K miles now...
Josh-
09-17-2013, 09:09 AM | #13 | |
69
Rep 1,943
true but it doenst mean hes never had a problem and when he does have one he made the tune software/hardware he can easily fix it unlike most if us reaching out 4 help for the most part. can anyone list the mechanical differences between 335i and 335is other than the exterior Mtech kit or the obvious?
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
09-17-2013, 09:15 AM | #14 | |
86
Rep 1,262
Josh-
09-17-2013, 09:19 AM | #15 |
16
Rep 197
The car has a heavy duty radiator fan for improved cooling, an additional smaller radiator on the drivers side front air dam(replacing fog lamps) and the improved oil cooler on the passenger side. Aside from that, the tune which as mentioned above is improved in all aspects, not just an over boost function.
To answer the initial question, the only way to get the function of the 335is is to tune your 335i but it wont ever have a temporary over boost function, that's only bmw's software, I could be wrong. You could get a tune and improve timing and air fuel along with more boost. I think bmw has proven that its safe and reliable to run 14 psi on these cars all day given that cooling is sufficient. |
09-17-2013, 09:48 AM | #16 | |
1003
Rep 3,396
09-17-2013, 10:23 AM | #17 |
3129
Rep 5,264
I don't think so. Terry's firmware takes advantage of the factory software does not replace it. He runs two different firmware versions for the 335i & 335IS
Kevin
09-17-2013, 10:59 AM | #18 | |
Brian335tt
98
Rep 1,227
09-17-2013, 11:39 AM | #19 |
86
Rep 1,262
you don't even need the bumper, even just an oil cooler would be fine, but then again I wouldn't advise anyone against upgrading the FMIC. The stock unit is garbage compared to even the cheap aftermarket offerings.
Josh-
09-17-2013, 12:48 PM | #20 |
69
Rep 1,943
so the mark up 4 335is is just on the cooling and cosmetic looks?
09-17-2013, 12:57 PM | #21 | |
86
Rep 1,262
People who own one will of course tell you it's the rarest type of E92/93 but how much does that matter IDK, still a mass produced model..
Josh-
09-17-2013, 01:37 PM | #22 |
Rep 252
what makes the stock unit such a piece of garbage?
