E85 pumps in nj
09-14-2013, 02:02 AM | #1 |
Rep 55
E85 pumps in nj
I downloaded an app and they showed me some stations in Newark that sell E85 fuel but I'll have to call in the morning to see about that.
Can people post in here where in nj they get actually got their E85 fuel? Maybe create this as a sticky if it helps everyone? Lets see if that will happen. Just locations of the E85 pumps. This isn't the thread to talk about pros and cons of E85. I'll make another thread for that haha. Post away!
2007 SGM 335xi 6MT (m-sport) jb4 G5 board/BMS DCI/BMS Clutch stop/CDV delete/AMS FMIC/BMS OCC/UUC SSK/KW v1/35% tint/OEM black lines/Lux v5.1/CF CSL trunk/AR downpipes/CSL reps/Forge DV/ BMS Charge Pipe/MORE TO COME
09-14-2013, 08:43 AM | #2 |
underground
67
Rep 333
Drives: alpine white 335 E92
Newark airport sells it.
10-19-2013, 06:45 PM | #5 |
208
Rep 2,558
There's also that Power Gas station in West Orange...
Question: Aside from the risk of being shot/robbed/mugged, the e85 should be legit from that station, right? No chance of the gas being tampered with / diluted out? I've been getting e85 from the Gulf Station at EWR, but it's a little out of the way for me, but I sometimes work by the Veteran's Hospital just around the corner from the Power Gas station in West Orange... would be SUPER convenient to just fill up a jug with some e85 and then get my e10 from my local Exxon...
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
10-21-2013, 01:19 PM | #7 | |
Rep 55
10-21-2013, 01:20 PM | #8 |
Rep 55
You guys are running e85 mix of some sort without upgrading the fuel pump with no issues?? Been hesitant to do a mix. Figures I would upgrade the pump first.
10-21-2013, 02:49 PM | #9 |
33
Rep 571
I used to run a mix when I was on the JB4. Map 5 adjusts accordingly, and you'll feel a nice difference just be sure not to mix a heavy mix. I would run about 3/4 tank gas 1/4 tank e85, sometimes a little more. I found my pump having issues when I'd run 1/2 e85 1/2 93.
-335xi---Innotech Exhaust---AR 3" Catless---Pro tuned---HPF FMIC---ER Chargepipe---KW V1---Injen DCI---BMW Performance Front Bumper, Rear Spoiler & Door Sills---Vorsteiner wheels---much more-
10-21-2013, 06:15 PM | #10 |
Rep 55
Nice. I'm going to test it out when I have to refill again. Excited!
10-21-2013, 08:08 PM | #11 |
Rep 55
Question:
Since the e90 tank capacity is 16 gallons, a safe e85 mix is 12 gallons of 93 octane and 4 gallons of e85?
10-25-2013, 08:19 PM | #12 |
Rep 55
So I went to the Power Gas station in West Orange. FYI, there are two Power Gas stations in West Orange. The one that sells e85 gas is on Sandford Ave. Got gas at 7ish. I had no problem at all. Safe area. Well lit and camera's outside. Seeing the e85 sign got me giddy. Took a few runs on 280. I did a 70/30 mix of 93 octane from Shell (v power) and e85 gas. Love the difference. As the driver, only felt the torque when I was really pushing it but not with this mix. Felt good. Maybe it's cuz I was paying more attention so I'll try this mix a few more times before upping the dosage.
10-27-2013, 12:34 PM | #13 | |
42
Rep 321
MHD/Wedge E60 flash/Alpina TCU /Fuel It st2/Dinan OC/RB inlets/Helix Fmic/Vrsf DP/Forge DV/BMS DCI/BMS CP/TC Kline SA/swift springs/MF lsd/OEM PE mod/front and rear M3 links/M3 strut brace/Powerflex race rear diff,camber link bushes/DEV diff brace/Megan toe arms/AKG Race subframe bushes/Hotchkis Sway Bars/18 TSW nurburring/Michelin PSS/BMW M perf 370mm Hexon RR600 on the way
10-27-2013, 04:11 PM | #14 | |
208
Rep 2,558
01-23-2014, 03:24 PM | #16 | |
16
Rep 26
Or south orange?
01-23-2014, 04:13 PM | #17 | |
135
Rep 691
205 Sanford St. Location, East Orange, NJ |
01-23-2014, 04:16 PM | #18 |
Rep 55
Didn't do any logging. Did it a few times and stopped cuz it started getting cold. I know a mix will add some moisture to the gas lines and it was getting cold. Don't want to run into any cracking issues. Planning on upgrading my fuel pump and gas lines in the spring and doing some logging.
01-23-2014, 08:31 PM | #19 | |
16
Rep 26
01-23-2014, 09:14 PM | #21 | |
681
Rep 3,696
Once i get a spare ride for the wife i gotta play some catch up to u |
01-23-2014, 11:14 PM | #22 |
135
Rep 691
No problem, but for anyone planning on using E85 once the weather gets nice.....
DO NOT BUY POWER GAS E85! Honestly it is crap, and has been tested to normally be in the 60% range. I have a straight E85 tune, and EVERY time last summer I used Power Gas E85, I had timing corrections (which should never happen on E85).... The Newark Airport Gulf Airport has E85, it's a bit of a bitch to get to the station but I've never had problems with the E85 quality. |
