DSC dead, any rebuilders out there? and can i buy used?
09-11-2013, 12:44 AM | #1 |
11
Rep 193
Sooo know you could get the older DSC rebuilt, can the new ones be rebuilt? Haven't had any luck finding anyone.
Also would there be any issue of buy a used one and getting it coded? looks like a ton of models have the same one but i dunno if it would work. Thing is stupid expensive >< |
09-11-2013, 01:24 AM | #2 |
Guest
Rep n/a
Drives:
Depends if the control module or actual mechanical part is dead, you could by a used one, transfer the module over then tow the car to the dealer to have the brake fluid bleed.
You need to have BMW specific tools to bleed the pump after replacement, its not a normal brake bleed that any shop can do. Or find a good BMW indy. |
09-11-2013, 10:45 AM | #3 |
81
Rep 177
Check out this tread/DIY http://www.e90post.com/forums/showthread.php?t=600057 if you plan on doing it yourself.
09-11-2013, 12:01 PM | #4 |
866
Rep 5,450
Only place I have ever seen that does it - unfortunately they are in the UK
http://www.ecutesting.com/bmw_abs_pu...ault_ate_.html
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
09-11-2013, 12:21 PM | #5 |
Thats all you need to know.
43
Rep 1,188
I'd get a new one, used can be trading 1 problem for another.
- M2 2018 LBB / Black
- X5 F15 2016 Mineral White / Black 1981 Delorean number 6489 |
