Water pump failure after engine detailed
09-10-2013, 11:27 AM | #1 |
12
Rep 282
Hey all,
So I just recently detailed my 335i engine bay, and about 2-3 weeks later my water pump blew leaving me stranded. I know my detailing method was very standard, explained below, but don't know the N54 configuration well enough to say whether misting degreaser / light water in the engine bay could cause such failure later on. Could it be the cause? Where is the water pump exactly? Has anyone else experienced such a case? Detailing process; Allow engine to cool to the touch Cover dual cone intakes with towels Lightly spray engine bay with water Lightly spray degreaser (P21S Total Auto Wash, non-acidic and supposedly engine/paint safe) Brush engine parts with damp wool brush Lightly rinse engine bay with water Spot detail problem areas with steamer & brush/MF towel Thanks for your input/feedback |
09-10-2013, 11:30 AM | #4 |
964
Rep 3,854
Drives: 330i, 135i
Plain coincidence I think. I dont believe washing your engine will cause your water pump to fail. The water pump is well down the bottom of engine. How many miles?
Dont forget to replace your thermostat as well. |
09-10-2013, 11:37 AM | #6 |
Kraut Driver
59
Rep 624
Drives: 2014 650i GC/2011 335is DCT
Not even close. The water pump is on the bottom of the engine. If you didn't have an undertray on for some reason it's going to get a lot more water down there than washing the engine bay. The electronics in the pump are sealed and gasketed. You'd have to submerge it to have any chance of getting water in there.
09-10-2013, 11:44 AM | #7 | |
Rep 232
09-10-2013, 12:04 PM | #8 |
12
Rep 282
Thought so. 56k miles.
My SA actually didn't state that the thermostat was a standard replacement item and that it needed to throw a code in order for them to justify replacing it under warranty (extended aftermarket warranty). I thought this was ludicrous. Also, the warranty company isn't covering coolant, bolts, or anything outside 3 hours man hours of labor (BMW quoted 4.5). So looks like $400 out of pocket. I sent a nasty email. How many labor hours were your quotes from BMW? |
09-10-2013, 12:06 PM | #9 | |
456
Rep 6,478
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
09-10-2013, 06:19 PM | #11 |
36
Rep 311
I believe the water pump is located on the passenger side sitting low behind the radiator. It should be able to handle direct water spray just due to the location of the part.
I had my waterpump start leaking on me and had it replaced under CPO. I had read that its easy to replace the thermostat in conjunction with the pump due to the accessibility so i asked if the would do that. They just charged me for the thermostat (part cost) since the labor and pump was covered. I tried looking what it cost and labor involved, but it doesn't list it. Stat was $126 |
