335i e92 normal oil consumption?
10-09-2007, 02:23 PM | #1 |
235
Rep 2,377
Drives: Perfomance Model 3
car alerted me at 4000 miles that i was at minimum oil level and asked me to add a quart. now i am at 8000 miles same warning, so i will add another quart this evening. i had an e46 coupe and never had to add this much oil? e92 oil consumption that much different? is this normal?
'18 Tesla Perfomance Model 3 White on White Performance Upgrade Pkg & EAP
*RETIRED* 2015 435xi GC [f36] | 2012 335i [f30] | 2009 z4 35i [e89] | 2007 335i coupe [e92] | 2001 325Ci [e46] *RETIRED* |
11-16-2007, 09:05 PM | #3 |
appreciate your car
Rep 351
Seems a bit much to me. But then depends on how high you rev your engine.
I went 8000 miles and still had 1/3 until the minimum.
My 335i
The Ultimate Driving Machine... |
11-17-2007, 08:06 PM | #6 |
Galactic Emperor
75
Rep 801
Maybe, but when I put a quart in the light went off. It might be the fact that I take short (2.5miles each way) trips to work and home every day. A quart in a month and a half does seem like a bit much for a brand new car though.
02-28-2008, 01:46 PM | #7 |
235
Rep 2,377
at 10,500 i added a 3rd quart, still haven't had my first oil change. i am getting close to my 1yr anniversary April 10th and my oil service indicator says another 1500 (i have 12k miles now) until my first oil change. i am just following the orders of my dealership and my car, but this can't be normal oil consumption?? 3 quarts in 12k miles?
02-28-2008, 01:48 PM | #8 |
Rep 83
i noticed that on a hill with the engine running the car will ask for oil, obviously as the oil all runs to one end. make sure the car is flat when the warning comes on
Alpine White E92 M3, 19", Black Grilles
02-28-2008, 01:54 PM | #9 |
235
Rep 2,377
it is parked in my flat garage, and i always wait a day or 2 before adding a quart. maybe its because i drive a short distance to work in city type driving? i don't drive my car that hard? everything else is perfect with the car, but even my last 325Ci would ask for some oil from time to time? i mean BMW is the ONLY car i have heard of that supplies you with a quart of oil to top it off? i think they should at least give me a couple of quarts as I shouldn't have to pay for oil under warrenty. (yes i know Mobil 1 only costs ~$6, but its the principle)
02-28-2008, 02:03 PM | #10 | |
ocasionally in crisis
52
Rep 2,358
i live in a small town so most of my trips are short... i may be crazy, and i do pamper my car, so in the mornings, if i have to do a short 2 mile trip, i will drive the car for 10 minutes first, wait until my oil is at operating temps, then i go the 2 miles .... note my car is a semi daily driver. IMHO, many short trips and not driving your hard hard at least once in a while = bad engine performance in the long run. my 2 cents
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
02-28-2008, 02:15 PM | #11 | |
235
Rep 2,377
02-28-2008, 03:31 PM | #12 |
pew pew
166
Rep 6,781
If it's consuming oil it is basically some oil getting past the rings and getting burned up. Honestly there isn't much you can do apart from replace the rings but nobody is going to go through that just for oil consumption. Keep a quart in your trunk...
There's lots of talk about break-in methods and oil consumption and all that. Believe what you want, but there's really not much you can do anyway so I'd be over it.
CSL replicas are now CSL counterfeits. Jesus saves, like Valentine1.
02-28-2008, 03:54 PM | #13 |
Modder Raider
753
Rep 8,633
Drives: M3
I had to add a quart after 5K miles.
I changed the oil to 0w 40 after 10k miles and added a quart after another 5 k miles, so it doesn't matter what oil is used IMO. So, I guess for me, I'm adding a quart every 5k miles. Hopefully it will get a bit better.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
02-28-2008, 04:05 PM | #14 |
23
Rep 464
Just had to add some myself. I wonder if this has anything to do with the high temps of the turbos? Oil Cooler? No idea just guessing...
2021 AMG E63S Hammer Wagon
2002 BMW Z8 (with a Dinan DP Engine) 1996 Porsche 911 (993) Turbo 1995 Ferrari F355 Berlinetta 6mt 1964 Porsche 356 C Coupe |
02-28-2008, 04:10 PM | #15 | |
52
Rep 2,358
rideelment just reported that after 1,000 miles there was about a teaspoon of oil in his catch can. if that oil (which came from the turbos and then ran through the iC chargepipes) reached the combustion chamber, after say 50,000 miles how much sludge (unburnt oil from the combustion chamber) would accumulate in the oil pan?? ...and will this be a problem? for these reasons i think a catch can is a good mod. i may not do the catch can mod only because if i run water/meth, the bit of oil in the combustion chamber (coming from the IC charge pipes) may be of some slight help with my meth injection. thanks
02-29-2008, 01:01 PM | #17 | |
37
Rep 794
Drives: 2021 M2C, 97 M3
Performance Center Delivery, June 21, 2013: 2013 E92 335is | Le Mans Blue | Gray Leather with Black | 6MT | 19" Style 313's | Michelin Pilot Super Sports | BMW Carbon Fiber Rear Spoiler | |
02-29-2008, 01:06 PM | #18 | |
37
Rep 794
02-29-2008, 01:09 PM | #19 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Welcome to my world. Car is in for service right now to replace a faulty oil sensor.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
02-29-2008, 11:18 PM | #20 |
Rep 95
Maybe OT... maybe not. 535i owner here at work has had oil issues since car was new. They were adding significantly more than a qt. per 4~5k miles. It is still in the shop for 2 new turbos. I am at 14,5xx miles on my 335 and have done a break-in and one other oil change (next one will be 15k) I have never had to add ANY oil. Indicator is still at Max level.
Delivered 02/20/09
LeMans Blue/6MT/EDC |
02-29-2008, 11:29 PM | #21 |
102
Rep 2,760
I am sure you mean 9000 km. BTW 8000 miles and still full. I have Dinan tune too.
Varies car to car, but mine been excellent so far. No oil consumption I can speak of. Driven hard sometimes too.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
03-01-2008, 08:58 AM | #22 |
DVM
Rep 77
Brake in durring E.D. on back roads and the Autobahn. Changed oil, M1 0-40, at 2000 mile. Currently 8500 and reading full. Car indicates that it expects an oil change at 9000. Great auto!
