3 AutoZone error codes, 1 identified, other 2?
09-06-2013, 02:36 PM | #1 |
Rep 97
ok, after having a "service engine" light come one, dropped by auto zone to have it checked out. Well, it showed 3 codes not sure if it was wrong errors codes showing up with "volkswagen" and "chrysler"?
P2402 - DMTL Pump or atleast dealing with the pump P1124 - ? P1197 - ? a quick search on, "old faithful" e90 Forum, found P2402 as DMTL pump, so need to see about troubleshooting it further. The other 2 So my question is, does anybody have any information on P1124 or P1197? Autozone guy, just said to take it to a mechanic, not much more assistance than that so here is some info off the tickets he printed out How serious does this look like? Only thing in common is "oxygen sensor? troubleshooting? Any help would be appreciated. Thanks in advance |
09-06-2013, 03:03 PM | #2 |
Rep 97
Ok, looks like this is what im looking for.... Any other links or info I may need, drop here
http://www.e90post.com/forums/showthread.php?t=459104 |
09-06-2013, 03:26 PM | #4 | |
just another bmw douche bag
195
Rep 3,640
I can see where this would be very helpful, like if you had a coil go out, but didn't know which one. You could have autozone read the code for you and then sell you a new coil you could install in their parking lot. |
09-06-2013, 03:33 PM | #5 |
Rep 295
According to my Bentley manual
P2402 - DMTL Activation Control Circuit High P1124 - Differential Pressure Sensor Intake Manifold Pressure Offset Bank 1 P1197 - Differential Pressure Sensor Intake Manifold High Input Bank 1 |
09-06-2013, 03:41 PM | #6 |
Rep 97
Yes, seems like auto zone, best they can do is give you the code? which is what i was looking for, i asked him, how many o2 sensors do the cars have 2,4, 20 sensors? he had no answer, i asked about prices and he said between 43-170$, but couldn't help me any further in identifying which one, so not much help aside from getting the codes.
After reading the thread i posted, here is a post there, so is the B1S2 sensor on the bottom of the engine, needing a lot of removal of parts? can someone confirm, the B1S2 sensor is a pain to replace? looks like, thanks Originally Posted by be-em-veh-808 Thanks for sharing your experience. Not excited about removing all the cowling, cabin air filter, and other items just so I can remove engine cover . So, when you removed the B1S1 sensor, did you have to remove anything that had to do with steering rack or tie rod? My Bentley manual said 'remove the right tie rod from the steering rack' Also, was removal of the sensor fairly straightforward --- or did you really have to work at it or use the big breaker bar? I bought an off-set type sensor socket --- is that what you use? Thanks in advance EFT! You must be talking about the B1 S2 O2 sensor then. The Bank 1 Sensor 1 is the O2 sensor in the top of the front exhaust manifold (cylinders 1, 2, 3) that you can easily see on the right side of the engine. This this for an N52 of course, which is the engine in your car. I have both types of sockets (off set and deepwell-split). Either should work. I did my sensor just after the time Eninty posted the DIY and the price for the OEM sensor (B2 S1) was $55 from Tischer. |
09-06-2013, 03:54 PM | #7 | |
Rep 295
09-06-2013, 05:50 PM | #8 | |
Rep 97
thanks for the post on the "DMTL" showing high, is that high voltage/current? and on the "Differential Pressure Sensor" is the an adjustment needed OR plain defective? any part number listed? Thanks again for the help in looking that up off to research some more Anybody have any idea if the 2 are related? |
09-06-2013, 08:05 PM | #9 |
Where'd my VTEC go?
481
Rep 6,067
Get the actual BMW codes read. They're more specific than the generic OBD2 codes.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
09-06-2013, 08:38 PM | #10 | |
Rep 295
I believe it is part number 13628617097 if your car is a 2006 325i E90 as listed. No. 12 http://www.realoem.com/bmw/showparts...11&fg=40&hl=66 http://www.thebmwpartstore.com/oempa...628617097.html http://www.ecstuning.com/Search/Site...097/ES2641334/ |
