NEED to replace the windsheild washer reservoir tube...
09-03-2013, 04:02 PM | #1 |
20
Rep 244
My windshield washer reservoir tube cracked and leaks every time i fill it up and allows the fluid to evaporate faster.
Does anyone have a how to guide on a replacement or a part number of just the windshield washer reservoir tube? Has anyone else had to replace this? Thanks in advance. |
09-03-2013, 05:34 PM | #2 |
Oil Burner
26
Rep 231
FOR E90
Necessary preliminary work: Remove front right side repeater light Partially remove front right wheel arch cover Clip cable (1) out of mounting. Clip hose (5) out of mounting. Unlock filler hose (2) and detach from fitting on fluid reservoir (3). NOTE: Catch any escaping washer fluid if necessary. Unscrew bolts (4) and (6). Pull fluid reservoir (3) forwards slightly Installation note: Retaining lug (2) of fluid reservoir (1) must be correctly seated in clip (3). Installation note: Replace strainers on washer pumps Coat sealing rings of washer pumps with lubricant Lay lines of washer pumps without kinks and clip into holders on fluid tank Fill fluid tank for windscreen washer system
'11 BMW 335d Sport
-JBD '07 Shelby GT500 -Not Stock |
09-03-2013, 05:40 PM | #3 |
Oil Burner
26
Rep 231
FOR E92
Necessary preliminary tasks: Partially remove front right wheel arch trim If necessary, remove right front wheel E92 without M3, E93: Remove front right auxiliary direction indicator Note: Catch any escaping washer fluid if necessary. Release cable ties (1) on fluid reservoir. Feed high-pressure line (2) out of holders. Unlock filler hose (4) and detach from fitting on fluid reservoir (5). Release screw (3). Pull fluid reservoir towards front. Installation: Retaining lugs (1) of fluid reservoir must be correctly seated in tabs (2). Disconnect all plug connections. Release cable ties on fluid reservoir. Remove level switch (1) Remove windscreen washer pump (2) If necessary, remove washer pump for headlight washer system (3) Remove washer reservoir. Installation: Replace strainers on washer pumps Coat sealing rings of washer pumps with antiseize agent Lay lines of washer pumps without kinks and feed into holders on fluid reservoir Fill fluid tank for windscreen washer system
'11 BMW 335d Sport
