Freaking limp mode, bet Ive got ANOTHER bad HPFP
09-01-2013, 07:49 PM | #1 |
965
Rep 5,032
I had a good run, almost 4k miles with no problems, but today while going to accelerate past a slow car on the freeway I got the dreaded limp mode/reduced power symbol on the dash. Last time this happened I scanned codes and they were misfires, and ended up being a bad hpfp.
Tuned BMW's can be so frustrating. Might be time to move onto something new. |
09-01-2013, 08:01 PM | #3 |
142
Rep 1,449
I wish we all knew why some could go for thousands of miles with no issues and others cant seem to catch a break
JB4 G5, VRSF catless DPs, FMIC, BMS DCI, Muffler Delete, Alpina B3 Flash, RB Turbos, BB Race Flash
09-02-2013, 02:00 AM | #4 |
965
Rep 5,032
09-02-2013, 02:01 AM | #5 |
965
Rep 5,032
09-02-2013, 09:18 AM | #6 |
19
Rep 595
Yes, this is a BMW software update. I would certainly make sure that it is updated because apparently the old software didn't supply fuel properly with the LPFP causing air cavitation on the HPFP, causing failures.
09-02-2013, 11:00 PM | #7 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
It could be a slew of other things aside from the HPFP. Bad plugs / coilpacks / injectors are other possibilities....
I wouldn't jump to conclusions quite yet. |
09-02-2013, 11:08 PM | #8 |
12
Rep 348
Drives: 2009 E92 335i
my 09 335 coupe is currently at the dealed and has been there for 5 days. I know this weekend was a holiday weekend but I was told on Saturday that they needed more time to figure out why I had a misfire in the #1 cylinder.
09-03-2013, 11:48 AM | #9 |
1705
Rep 14,829
Sometimes I find our cars mysterious. Based on the mass hysteria, I purchased a 7/100 factory extended warranty. It's going to expire totally unused. Then I read the threads about spark plug replacement, and people break the coil packs, plugs get stuck in the head, cars run rough after the change, one person even said you need to set the adaptation. I DIY my plugs yesterday, nothing breaks, and it runs like a champ on Bosch not BMW plugs (green vs. blue). Is my car an anti-BMW?
09-08-2013, 07:37 AM | #10 |
Master Gunner
77
Rep 435
Drives: 2008 335i Sport
I incorrectly jumped to the conclusion that it was my HPFP as well when the half-shaded engine warning light would come on: if light acceleration to 3,500-ish the light would remain on but no limp mode; if under hard acceleration to 4,000-ish the light would flash and car would go into limp mode. Everything cleared when engine turned off. Other than that, engine seems to run just fine and I've driven two different, several-hundred-mile-long round trips that so long as I kept below 3,500 RPMs drove just fine.
I went to dealer to get it troubleshooted and after tearing out a few things to get to the root cause, determined it to be the "other" common problem of a failing waste gate on one of the turbos that when it started to truly boost would cause the fault. Turbos are out of warranty, but though I'm bummed about the turbos going bad before I expected it, it's a perfect excuse to upgrade to Vargas stage 2 turbos! Actually, I'm quite excited of the prospects as this was my end goal eventually; it's just now the timeline has been moved up. Luckily, I can still drive the car while I collect the full package: turbos, HPF intercooler, Active Autowerke's exhaust, Cobb tuner. |
09-08-2013, 07:48 AM | #11 | |
1705
Rep 14,829
09-08-2013, 08:27 AM | #12 | |
Master Gunner
77
Rep 435
According to the Service Advisor, the "codes" they scanned indicated the turbos were the culprit (actually, I now recall him mention vacuum related issues to the wastegates) and they tore out whatever they could to get as close to the turbos to examine their function and inspect them as close as possible in order to verify their disgnosis. Now, whether those codes were truly turbo-specific codes or whether they were other codes that were symptomatic of turbo-related issues, I do not know. Whenever I get my INPA/DIS setup sorted out (and actually learn how to use and interpret the results displayed), I will examine whatever codes that show up whenever I trigger the warning light. EDIT: Regarding the INPA/DIS, what I'm actually planning on doing is setting up a different laptop to run Windows XP as this seems to be the ticket for running as flawless a DIS installation as possible. DIS seems to be the best diagnostic tool for "dummies", but runs in a virtual machine that requires a fully functioning INPA/EDIABAS installation. Not only that, but I can run a mostly English version of NCSExpert, whereas with the x64 compatible version of NCSExpert, the actual program is still in German even with the English config translation text file installed. BTW, even with the 3,500 RPM wastegate issue, the car has way more power than my 2003 325i; there doesn't seem to be any performance issue and pulls nicely until I hit that 3,500 threshold. Of course, no WOT for me until I replace the turbos... Last edited by Augster; 09-08-2013 at 09:51 AM.. |
