will e39 m5 wheels fit my e90??
12-06-2005, 10:08 PM | #1 |
vucorp & sons
13
Rep 140
does anyone know if e39 m5 wheels (replcias) or real ones will fit my e90? i looked around but havent found any e90 running on e39 m5 wheels. i'v seen the neweest m5 wheels but not the e39
12-06-2005, 11:41 PM | #2 |
Rep 132
hi vu, check out my thread as I'm running e39 M5 replicas for my winter setup:
http://www.e90post.com/forums/showthread.php?t=7891 Others have the same wheels and there are no fitment issues with 330i (larger brake rotors) so I'm sure it will be fine on your 325i. |
12-07-2005, 12:13 AM | #3 |
vucorp & sons
13
Rep 140
Hey thanks! they look good. i'm looking at 18's in this wheel for my e90. what is the size wheels are they? i know it's 17's, is it 17x8? what is the offset from and rear? is the rear kinda of concave (goes in?)
thanks again.. they look really good |
12-07-2005, 09:58 AM | #5 |
Rep 132
yeah, bimmerista and i have the exact same setup.
I believe the offset is +38 but I'm not positive. And because the wheels are the same 17x8, the rear wheels do appear "tucked in the body" and the look would be improved with the use of spacers. The fronts look fine but the rears could be improved. I've read some bad things about running big spacers (say 20+mm) in that they may put undue strain on the suspension but "your mileage may vary". If you run 18", you may be able to find a staggered setup say 18x8 up front and 18x8.5 at the rear and that would look good. |
12-07-2005, 12:50 PM | #7 | |
117
Rep 643
IMO, the optimum offset for the rear with 9.5" inch wheels is 27-28mm. |
05-10-2010, 03:30 PM | #8 |
Rep 2
e39 M5 rims on e90 325i
I am not clear on the verdict...
So what would be the harm of putting e39 M5 double spoke style 65 rims on the e90? The e90 stock rims have an offset of 34 all around and these are 16x7 rims with 205/55/16 tires. The e39 rims have an offset of 20 at the front (18x8.5 rim with 235/35/18 tires) and offset of 24 at the back (18x9.5 with 275/35/18 tires). Would these rims wind up harming the car mechanically? Is it a question of them not fitting properly (rubbing/turning radius)? Is it a question of aesthetics? Please provide your feedback as I may be purchasing these rims from a local seller this week. Thank you |
05-11-2010, 11:22 AM | #9 |
1569
Rep 29,202
e39 has a larger hubcenter must other BMWs, incl. the e9x. 74.1mm vs 72.6mm. So you need some hubcentric rings.
And ET20 and ET24 is rather aggressive for an e90.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
