Do you guys think my wheel bearing is done?
08-31-2013, 07:49 AM | #1 |
72
Rep 702
Makes a VERY subtle wob wob wob noise when driving despite alignment. Also When braking or when the car slows down, I hear this grinding noise, that at times is very loud..
08-31-2013, 08:20 AM | #3 |
103
Rep 2,783
You may want to check your tires. When you posted wob wob wob you gave me a flashback. http://www.e90post.com/forums/showth...light=Run+flat
Not sure about the noise upon braking which may be rotors. If it is not those items then I would check bearings.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
08-31-2013, 08:21 AM | #4 |
Rep 232
Take two hair pin highway on or off ramps....one curving left the other right. If the sound doesn't go away in one of them (since you would be unloading one side of your car in each) it's not your wheel bearing
