2011 335i (N55) engine blown at 30,000miles
08-30-2013, 11:26 PM | #1 |
42
Rep 448
I thought it was worth posting that no matter how well you look after, maintain and respect your car, there are them bad apples out there that may bite you for no apparent reason.
As the title states my 2011 335i went bang last Friday at about 30,000 miles. No tune, no mods Purchased in March at 25,000miles as a CPO car from a BMW dealer I drive gently when cold and have never revved to the rev limiter and certainly never money shifted. My mpg log will tell the story that the car is not driven hard. Oil service was performed at 20,000miles under maintenance plan and again at 27,500 miles (in May) out of pocket where I requested 10w-60, performed at a BMW dealer. 2 weeks ago it had a scheduled inspection service. On Friday afternoon at running temp I felt power drop off and noticed the yellow oil icon appear on the instruments, the I-drive flashed something about engine hot or engine temp, but they went away just as quickly that I didn't have time to look again and process what it was saying. The car was in limp mode but did not have any red lights or gongs that indicated I should pull over and turn off. After a few hundred yards the power came back and I figured it must have been a bad oil sensor or something, so I continued on. This was again followed by power loss that would allow me to rev up to 4,000 or so, them shudder like I was running out of gas. When I pulled over and pulled away again there was an engine knock, not horrifyingly noisy, but there. I called BMW Assist and scheduled a tow for Saturday morning as it was safe where it was and I didn't want to spend hours waiting for a tow truck. Oil reading was full, no loss of coolant and temp gauge was at running temp. I tried to restart before leaving the car and it wouldn't fire, the engine turned, but as though the battery was dying....this wasn't going to end well. Saturday morning it started up...but with an engine knock and it got towed to the dealer. After removing the oil pan the dealer found "metal everywhere" (their words) and were instructed to send pics to corporate, I suspect a warranty department of BMW NA. A few days passed and they have approved a new engine under warranty. Dealer does not have any more info as they have to follow instructions and may not strip the engine at will, it will be sent to the lab for investigation. Perhaps the only reason I am posting is as a warning to those who perhaps don't have the means the cover a replacement engine and your warranty is about to expire, that extending it may be a good idea, you can get zero % financing on BMW extended vehicle protection plans if you need the assistance. Ask your local dealer. I am annoyed that I will no longer be able to claim that no car I have owned, new or old, has ever had a catastrophic issue, because I look after them. Despite this, I will probably continue buying BMWs... FYI, this is my 4th BMW, live BMW, and cars in general, avid bimmerpost reader and contributor and BMWCCA member, you think it'll never happen to you.
2011 E90 335i M-Sport 6MT Alpine white - saddle brown
2012 E70 X5 35d Sport Activity - Alpine white - black 2005 Toyota 4Runner 4WD Sport Edition Silver |
08-30-2013, 11:29 PM | #2 |
Guest
Rep n/a
Drives:
Every car ever made on a production line will have a premature engine failure, your one of the unlucky ones, look at the positive side, you are getting a new motor, no such thing as a production process with 0 percent defects, this is why we have a warranty.
08-30-2013, 11:35 PM | #3 |
294
Rep 1,311
As the old adage goes, "To err is human" and to expand on that, "At some point in time, what humans create will no doubt err". Glad you're getting a new engine at no cost. Whew!
08-30-2013, 11:36 PM | #4 |
42
Rep 448
Agreed. I am quite excited that I get to run in a new engine myself this time, haven't done that since I bought my 4Runner 8yrs ago. I just don't know how I would stomach this if it was out of warranty.
08-30-2013, 11:36 PM | #5 |
406
Rep 3,583
Drives: 2017 M3
every car has to break down one time.. mine did.
08-31-2013, 02:07 AM | #6 |
E60 to E90 to E92
Rep 107
[/SIZE]What was the deciding factor in using thicker M-spec oil in a non-M motor that was designed to run on 5W-30?
2011 E92 335i 6MT (Space Gray/Coral): M-Sport / Premium / Convenience / Navi / L7 / InvisiGuard / Dinan Exhaust & Pedals
2011 CR-Z EX 6MT, 2008 GSX-R600 RETIRED: 2008 Dinan M5 SMG, 2006 330i 6MT, 2006 Dinan 550i 6MT, 1992 Accord EX 5MT |
08-31-2013, 04:55 AM | #9 |
39
Rep 1,558
Hopefully the warranty department doesn't look at your service history, because I would be surprised if they covered that with 10W60 being used. A little too heavy for the N54/55. Good luck either way, I would be prepared though........
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback |
08-31-2013, 05:59 AM | #10 |
17314
Rep 18,737
Agree. What needs to be understood is bearing clearances are designed with a specific oil viscosity in mind. It is best to follow the manufacturer's recommendations for oil viscosity. Heavier weight oil does not equate to better lubrication performance.
08-31-2013, 06:16 AM | #11 |
1705
Rep 14,829
imho you have no idea what happened with this vehicle for its first 25k.
I'm the original owner of my 2007, and I purchased a 7/100 extended warranty, and never used it even once. CPO means nothing, it's a means of charging more for a car. My advice is if you buy a car new, you absolutely do not need an extended warranty, that money that goes to the warranty can be spent when/if repairs arise. Too bad I had to learn the hard way. Imagine, a N54 with zero issues in the entire extended warranty period. I flipped FB stock to make up for it (made 7,600, lost 2,900 on the warranty), such is life. |
08-31-2013, 07:23 AM | #12 |
1785
Rep 3,066
08-31-2013, 07:34 AM | #13 |
El Greco Capitan
309
Rep 1,051
Very odd and WRONG that you requested the ///M Spec oil for the 35.....! But what is even more troubling is that they agreed to go ahead and service it with the specd oil you asked for as if they don't know even better....!
by the way, 140K here, original owner got it in sep of 2006 been modded since 4K with turbo tuner and now Rev3 Aggressive e85 FBO, NOT A SINGLE problem. it's all about maintaining your vehicle the RIGHT WAY.
No, it's not new. It got 150.000+ miles on it
08-31-2013, 08:29 AM | #14 | |
42
Rep 448
I have had the joy of owning only 1 brand new car so far, my 2005 4Runner which I still have with zero issues at 130,000miles. The next BMW needs to be brand new, ED and all ;-), the additional upfront cost is earned back in the longer period of ownership of a trouble free car that you specced just as you wanted it and perfectly maintained from new. Nice to hear of a trouble free 335 as it has a pretty bad reputation for reliability generally speaking, and I had hoped to have a story like yours.
08-31-2013, 08:36 AM | #15 |
42
Rep 448
To those commenting negatively on the use of 10w-60. I did so after some research, Mike Miller's responses in Roundel, discussion with my BMW master tech, a personal friend, and consideration of the high temps it was going to operate in, reaching 100F here this week.
In short, this is not what caused it. I suspected some responses would jump on it and if you have an engineering background to explain how this difference in viscosity would most certainly have caused the problem, then please share it. The forum should be used for sharing constructive knowledge in a collegial manner.
08-31-2013, 08:40 AM | #17 | |
1705
Rep 14,829
I too have had zero issues since April 2010, and I got the warranty around July 2010. |
08-31-2013, 08:45 AM | #18 | |
1705
Rep 14,829
But what I never got was back when there was 10W30 and 10W40, 10W40 implies a greater range, yet people said it was "too thin." How so? But the reality is you can't have it all. Say a torque wrench to do the plugs, 5 to 75 is better than 10 to 100, even though you want 17 which is within both ranges. Because the torque wrench is not accurate at the low end, say below 20% of it's range. I suspect there is something along those lines with oil..... |
08-31-2013, 08:55 AM | #19 | |
Rep 232
08-31-2013, 11:12 AM | #20 | |
65
Rep 515
08-31-2013, 11:23 AM | #21 |
72
Rep 278
Noob question : If say one had lost a N55 engine and had to replace it at own expense. How much would it cost? Would the DME need to be replaced as well with the new engine?
08-31-2013, 11:29 AM | #22 | |
1705
Rep 14,829
I had a buddy replace an X5 motor and the dealer wanted $16k. He was 4k out of warranty. He argued until he was blue in the face, waited a few days, and suddenly he was out only 8k. My wild guess is more than 10k and less that 16k. Oh wait, there's a member on this forum who claims edmunds knows everything because they track stuff and junk. Wonder what emdunds says? |
