Draining coolant
10-06-2007, 06:18 PM | #1 |
788
Rep 7,246
Draining coolant
I've searched in the DIY section and searched the site with the search engine, but nothing. I want to know how to drain the coolant in the N54 engine (335).
LTMW Widebody+1M front bumper+Slek CF Lip|M3 Hood|StopTech BBK|M-Sport Rear Bumper+DD CF Diffuser|Custom Recaro Seats|KW V2|BavX LS3|M3 Side Skirts+Custom CF Lip|BBS CHR 19x10.5+BBS Lugs|LCI Taillights|RD Sport Anti-Sway Bars|GIAC S2|ER Intercooler+CF Shroud+Charge Pipe|Tial BOV|Injen Intake|MS downpipes|Custom Exhaust|BMS Oil Catch Can|M3 DCT wheel+TiD CF Paddles|BMW CF Trunk Spoiler|Aluminum Pedals |
10-08-2007, 10:30 AM | #2 |
26
Rep 1,826
Drives: E92 335i
Dude, you just can't get an answer to this question, can you?
The best I've found so far is "there's a drain plug down there somewhere". |
10-08-2007, 12:29 PM | #3 |
BMW TECH
Rep 104
Drives: 2008 328I SEDAN - 2008 BMW 750
According to repair instructions the first thing you have to do is remove the intercooler - then open radiator cap, then you open drain plug on underside of radiator (can only be seen with intercooler removed - according to instructions i have) then unfasten and detach coolant hose from thermostat housing. (see the pics I have provided)
I hope this helps
Current Vehicles - 2007 335i Sedan & 2005 X5 3.0
Past Vehicles - 2002 525I, 2003 325 Loaded, 2006 330I CURRENT MODS: PROCEDE V.2 - DYNOTUNE DIGITAL BOOST GUAGE - K&N AIR FILTER- INTERMEDIATE CAT DELETE - LOGIC HVI - |
Bimmer 808170.00 |
10-08-2007, 01:48 PM | #4 |
26
Rep 1,826
Drives: E92 335i
Hey, thanks!
10-08-2007, 07:16 PM | #5 | |
Samtaro!
124
Rep 2,601
10-09-2007, 02:18 PM | #6 |
BMW TECH
Rep 104
Yes there is here it is ---
Adding coolant: Note: Open vent screw on expansion tank. Fill coolant expansion tank up to lower edge of filler neck with recommended coolant. Observe mixture ratio. 50/50 MOST CLIMATES Close bleed screw. Close cap on expansion tank Note: Do not open the coolant expansion tank cap during the venting procedure. 1. Connect battery charger. 2. Switch on ignition. 3. Set heater to maximum temperature and turn fan down to lowest speed. 4. Press accelerator pedal for 10 seconds to floor. Engine must not be started. 5. The venting procedure is started when the accelerator pedal is pressed and takes approx. 12 minutes.(Electric coolant pump was activated and shuts down automatically after approx. 12 minutes). 6. Then top up fill level in coolant expansion tank slightly above max 7. Check cooling system for leaks. 8. If venting has to be carried out again (e.g. if cooling system is leaking), allow DME to fall completely (leave ignition key removed for approx. 3 minutes), then repeat from Point 3.
Bimmer 808170.00 |
11-10-2007, 11:24 AM | #8 |
97
Rep 399
Drives: 2023 BMW i4 eDrive40
Coolant Repalcement Interval
MBMWTECH,
Is the BMW coolant really a "lifetime" coolant? My dealer told me that it does not need to be replaced every 24 months as I have always done with other vehicles that I have owned. How often should it be replaced per BMW? What does "lifetime" really mean? Thanks Wallyf |
11-10-2007, 11:28 AM | #9 | |
Smiling Politely
1381
Rep 29,118
with Mercedes benz life time coolant is 15years or 150k
02-11-2008, 02:56 PM | #11 |
119
Rep 2,909
Does anyone know what the flush procedure is for this?
'06 E90 325i (Delivered May '05) 6-spd manual, Nav, Xenons, 18' 162's, sport-suspension, 15mm RE spacers,
NURBURGRING: http://www.e90post.com/forums/album.php?albumid=3270 |
02-11-2008, 03:04 PM | #12 | |
40
Rep 494
Any good ideas |
02-11-2008, 03:09 PM | #13 | |
119
Rep 2,909
02-17-2008, 01:27 PM | #14 | |
72
Rep 613
02-17-2008, 02:05 PM | #15 |
50
Rep 1,600
Drives: e90 335i
Thats what I was thinking. How about this, say I want to replace the current mixture in the radiator with distilled water and water wetter since I have heard this can really help temps compared to the 50/50 coolant/H2O that comes in the car. Anyone care to post a DIY for the simplist method? I wouldn't really care whether or not I could get every last drop of the current coolant out, 75% or more would be fine. I can't believe the first step really has to be "remove the intercooler", I mean wtf is that all about?
07-14-2008, 11:12 AM | #16 |
75
Rep 1,288
Drives: 135i
Is there any easier way of draining the coolant then removing the friggin intercooler?
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
07-14-2008, 02:08 PM | #17 |
Gruppe Titan
262
Rep 2,839
Drives: 08 E92 SG/Coral
Someone mentioned just using a siphon to get the fluid out.
07-14-2008, 03:09 PM | #18 |
119
Rep 2,909
It's neccesary if you want to flush the entire system out... If you are going through the trouble of changing it out, you might as well flush it too.
07-14-2008, 03:17 PM | #19 | |
Modder Raider
753
Rep 8,633
Drives: M3
This is great information.
Do you have the Bently CD or are you a tech? Quote:
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
07-14-2008, 03:19 PM | #20 |
152
Rep 2,461
bleeding coolant isnt the hard part....bleeding teh AIR AFTER putting new coolant in and making sure you have NO air in the system IS the hard part!! Trust me on this, if you have air in your system you wont know until the winter/cold when you turn on your heater and it blows cold/luke warm air.....
07-14-2008, 06:00 PM | #21 | |
Modder Raider
753
Rep 8,633
Drives: M3
I've heard this plenty of times with brakes but never with coolant.
07-14-2008, 06:04 PM | #22 |
119
Rep 2,909
It's off of the BMW maintenance DVD...
