PROcede V2 switched power on newer cars without the fuse
10-06-2007, 10:57 AM | #1 | |
Moderator
270
Rep 4,481
Took me some time today and can provide the solution now. Shiv's criterias are met. Of course, the wire has to be intercepted as we know it from all PROcede wires ( different connector size ). Power distribution is perfect. Power is switched on when you open the car, no interruption during engine start, power off is when the car falls to sleep some minutes after you shut off the car. Here is the location ( please excuse the poor picture quality ). It's the red thick wire on the black connector. On this connector there is only one red thick wire. Standing in front of the car the connectors on the picture are located in the rear, left corner of the ECU box. This is also an excellent power source for datalogging equipment. Some Innovate Mororsport devices have to be powered on some time in advance you start the engine and calibrate in this time ( e.g. DL-32 MAP ). The car-pc will be comfortable with a power source being available for some time after shutting down the engine and no power interruptions once you have to crank the engine multiple times. If you plan to hook on additional devices to this power source, I would recommend to use a relay. Enjoy the solution ! - Eugen Last edited by e.n335; 10-06-2007 at 01:13 PM.. |
10-06-2007, 04:26 PM | #2 |
153
Rep 5,780
Did you pop the pin and see if it is the same as the ECU connection? I wonder since I have a set of sockets and pins in the garage which need a home and would made for a clean install.
TIA... |
10-06-2007, 04:42 PM | #3 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
So I guess the only problem is that you need to tap into the wire and that will leave behind a trace, where the older cars with a fuse didn't leave behind anything. Is there any way to tap for power using some type of connector? The only thing that I know of are wire taps, and that's not ideal. In any case, nice work eugen.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
10-06-2007, 04:56 PM | #4 |
74
Rep 1,271
I thought Eugen meant that you would extract it and connect it to the procede, via an updated Procede harness for V2 that incorporates that wire - so there would be no cutting or tapping.
10-06-2007, 05:24 PM | #5 |
Moderator
132
Rep 6,775
Oh, ok... I must have misunderstood. Thanks.
-Michael.
10-06-2007, 05:47 PM | #7 |
Rep 110
Good one , now check the nominal durrent draw. Also what is actually powered by the wire?
Vette C5sc427a4 699rwhp at 11psi(Pending 15psi)
BMW 335I sedan Mit Lancer Lex RX300 |
10-06-2007, 08:52 PM | #10 | |
Moderator
270
Rep 4,481
However, enhancing the harness ( 1 short wire with 3 connectors ) would be Shiv's job, not mine. The PROcede including its V2 harness is working fine directly connected to this power source. I will use the power source to drive a relay because I need more devices connected to this kind of switched power. I'm happy I found it . - Eugen |
10-06-2007, 09:03 PM | #11 |
Under the radar
41
Rep 840
I like the green clip better where they all (orange switched power wires) meet. A small blade or bullet style male connector into the top will fit snugly. I had better luck with the bullet style, as it was a bit longer and more narrow.
No extraction required. |
10-06-2007, 09:06 PM | #12 |
153
Rep 5,780
10-06-2007, 11:04 PM | #13 |
54
Rep 1,677
How do you know if your ca is "new" and doesn't have the fuse without cracking open the ECU compartment? I don't have my prod. date cus idk how to find it, but i bought the car about 3 - 4 months ago.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
10-06-2007, 11:15 PM | #15 |
54
Rep 1,677
I know. My question was, when I piggy back my car, I dont want to walk out and open the ECU compartment to find out I have no fuse there. How can I tell beforehand is my quesion
10-06-2007, 11:20 PM | #16 |
26
Rep 1,826
Drives: E92 335i
10-06-2007, 11:25 PM | #17 |
54
Rep 1,677
but its a PITA
10-06-2007, 11:29 PM | #18 |
اوليسيس
196
Rep 4,678
not really.....it just seems that way the first time you do it.
10-07-2007, 12:54 AM | #19 |
405
Rep 6,107
Hey Eugen ,
Is it possible to connect Procede ( not V2 ) to the same wire, so you can have switched power even if you don't have V2 yet ? It would help a lot if you can maybe take more pics and do some kind of DIY . Thank you! Last edited by doba_s; 10-07-2007 at 11:16 PM.. |
10-07-2007, 12:57 AM | #20 |
74
Rep 1,271
10-07-2007, 03:12 AM | #21 | |
Moderator
270
Rep 4,481
No, it is not possible to hook up PROcede V1 to this power source. V2 supports to be hooked up to switched power. On V1 you would need a power source which wakes up together with the car's ECU when it does the periodic sensor checks ( every 14-15 minutes ). This new power source does not wake up together with the ECU when the car is shut off. - Eugen |
10-07-2007, 06:36 AM | #22 |
47
Rep 507
Hi Eugen Nice work,have you found any place for ground inside the ECU box.
That would make V2 invincible now that we dont need to bypass the boostcontrol anymore. |
