My car has stopped using DEF
08-24-2013, 02:41 AM | #1 |
Rep 125
Last time it was added was something like 17k miles ago, since then it's never popped up the warning to add more.
The car was involved in a minor rear end accident that caused the rear bumper and trunk to be replaced, I wonder if the body shop somehow disconnected the DEF crap. No CEL or anything to note, car seems pretty normal. |
08-24-2013, 06:28 AM | #2 |
411
Rep 3,049
Drives: 2009 BMW 335d
I highly doubt it. You're most likely running low on it.
08-24-2013, 07:00 AM | #3 |
Retired TDI guy
Rep 89
Drives: 2009 335D
how long should we be able to go between fills?
08-24-2013, 08:43 AM | #4 |
3596
Rep 10,358
08-24-2013, 10:51 PM | #5 |
20
Rep 298
if you get high gas mileage, you'll use less DEF than if you get poor mileage. I think for every gallon of diesel, 3% of a gallon of def is used.
08-24-2013, 11:55 PM | #6 | |
Rep 125
The last time the car was serviced by BMW was before the warranty ran out, just under 48k. My independent doesn't stock DEF, so I figured I'd just add it myself when the warning pops up. Car is nearing 66k now. |
08-24-2013, 11:59 PM | #7 |
Rep 125
According to that, if I divide my mileage by my average mpg, I should have used nearly 17 gal of DEF in that time. I think the tank is like 6.
08-25-2013, 09:23 AM | #8 |
143
Rep 634
Think it's closer to a 1% ratio, but no more than 1.5%. At 1 % you should be turning on the 1000 miles to no start any day now. Think it's impossible to stop using DEF because there are too many sensors monitoring the exhaust stream. For example if you filled the DEF tank with water and the conversion to reduce NOx was no longer occurring it would know and you will get a SES.
09-10-2013, 08:08 PM | #9 |
Rep 125
So since I've made the thread I've gone another 2200 miles. Now showing 19,300 since the last fill at the dealer.
No SES, or warning. But, the car is doing a DPF regen just about every other time I drive it it seems like. Mileage has fallen off also as a result. |
09-11-2013, 06:59 AM | #10 | |
3596
Rep 10,358
It has been a couple of weeks. Why haven't you had the SCR system checked? Are you SURE about the mileage? |
09-11-2013, 01:42 PM | #11 | |
Rep 125
My independent shop who does maintenance since the warranty has expired doesn't stock DEF. I've been waiting for the light to go on, and I'll add it myself. I usually get good mileage with my car, my lifetime average is around 37mpg. But even so I'd always need DEF at every oil change, and once I needed it 2,000 miles before. I haven't had it checked because obviously the car is out of warranty. |
09-12-2013, 06:49 AM | #12 | |
3596
Rep 10,358
