The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > OFT Stage 1 Datalog
      08-16-2013, 07:41 AM   #1
BD_F22
BD_e92
358
Drives: 2015 m235i xDrive
OFT Stage 1 Datalog
Did a datalog the other night (2nd all the way through 3rd to redline) and just wanted to how you guys think my car is running.. My mods are BMS DCI and AE performance exhaust.. temps were in the mid 70s and i run only shell 93 vpower gasoline
      08-16-2013, 08:33 AM   #2
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
suggestion for these OTS maps ... perhaps you can adjust the scalar upwards a bit to keep the trims from being so close to tapped? easy enough to do in TunerPro.
      08-16-2013, 08:33 AM   #3
135Pats
135Pats's Avatar
456
Drives: A few BMWs
These graphs continue to bemuse me, but it looks fine outside of some minor timing retards. Likely due to IAT comp tables, look at your charge temps by the end of the pull. You need a better intercooler! Delta of almost 100 degrees in terms of charge temp after a 2 gear pull, not what you want. Boost curves, AFR, etc look just fine to me. Maybe a bit tight on trim? I’m sure PROcede folks will chime in, it takes me a few minutes just to figure out what the hell I’m looking at with the graph style data logs.
Why do PROcede logs do so much better with AFR than JB logs? Don’t mean to derail this or start a tuner war, but 80% of the JB logs I see are running quite lean. It’s a DI motor and JB is proven, so I’m not saying it’s unsafe…but it does strike me as odd when AFRs are 14 at peak boost.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII
      08-16-2013, 08:43 AM   #4
JStang
JStang's Avatar
562
Drives: FDB M3 CS
Trims are very close to being maxed out. You need an intercooler in a bad way.
      08-16-2013, 08:57 AM   #5
BD_F22
BD_e92
358
yeah helix fmic is definitely my next mod just waiting to get my mtech front bumper to do it all in one shot and get more air to the intercooler
      08-16-2013, 08:59 AM   #6
BD_F22
BD_e92
358
thanks for the response, helix fmic will be purchased within the next month or so
      08-16-2013, 09:00 AM   #7
ZTUNER
21
Drives: 91 Z32TT, 2000 I30, 335i
Seeing low timing and timing drops. Ait is super high. I bet if you could log all cylinders you would see timing drops all over the place. Fuel trims are high too. IMO, trims should be in the +- 10 % range to leave some headroom. Overall not too impressed. You need a fmic like yesterday.
Harry
      08-16-2013, 09:05 AM   #8
BD_F22
BD_e92
358
Harry
just out of curiosity in your opinion will the fmic aide in correcting most of these issues or do i have more than a fmic to worry about?
      08-16-2013, 09:09 AM   #9
jippii ensio
68
Drives: 335i
What's your mileage? IATs are high even for a stock FMIC. Something like if you would have it fully exposed and it had been hit by stones and crap.
      08-16-2013, 09:10 AM   #10
135Pats
135Pats's Avatar
456
Drives: A few BMWs
Charge temps are through the roof, and the car is very likely pulling back timing as a result. Whether that solves all the “noise” is tough to know, esp. since your log doesn’t show all 6 cylinder corrections. But to be clear, your car is not enjoying those types of CATs.
F30 N55 XDrive EBII
      08-16-2013, 09:10 AM   #11
BD_F22
BD_e92
358
39k miles and its definitely not fully exposed i have the stock bumper with the lower grill on it
      08-16-2013, 09:14 AM   #12
jippii ensio
68
Drives: 335i
Sorry, I meant exposed to stones as without the grill. Bad condition of the FMIC would have explained the high IATs.
      08-16-2013, 09:16 AM   #13
JStang
JStang's Avatar
562
Drives: FDB M3 CS
45 degree increase from beginning to end of a 2-3 pull is probably pretty standard for the stock FMIC in hot conditions. My IAT's climbed from 117 to 148 during a 1/4 mile pull in 85 degree, humid, Florida weather with my 5" ETS FMIC.
      08-16-2013, 09:31 AM   #14
BD_F22
BD_e92
358
how do you like your ets fmic? i was deciding between the helix and ets.. just wondering how you think it performs
      08-16-2013, 09:35 AM   #15
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
its an upgrade over stock but nothing special. id spring for a 7 inch FMIC. (I have the same 5" ETS)
      08-16-2013, 09:39 AM   #16
JStang
JStang's Avatar
562
Drives: FDB M3 CS
+1. It does it's job but not as well as the 7" would. The 5" has a tough time keeping up in the summer.
      08-16-2013, 05:25 PM   #17
timtech
timtech's Avatar
25
Drives: M3
Does that mean you logged a WOT pull in 2nd from 2,300ish to 6,500ish?
      08-16-2013, 05:48 PM   #18
BD_F22
BD_e92
358
No, WOT pull from about 2,000 in 2nd all the way to 6,500 in 3rd then i shifted into 4th and stopped it
      08-16-2013, 06:41 PM   #19
OpenFlash
1737
Drives: A Lot
His in-gear fuel trims trims peak at 22%. And at redline. Not really what I would consider close to maxed out. But I agree that an intercooler certainly would help. But I think that applies to anyone with a stock FMIC who isn't driving in Alaska
      08-16-2013, 06:48 PM   #20
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
I don't understand why you are so against having trims closer to 0. it allows the DME more adjustment range on both ends of the spectrum.
FWIW, I like to keep my trims around +10 midrange down to 0 at redline.
      08-16-2013, 06:50 PM   #21
OpenFlash
1737
Drives: A Lot
Where do I say that I'm against that? I merely said that his trims aren't "close to maxing out" as others have reported. If the OP wants to increase the fuel scalars, he is free to do so. But not out of necessity.
Shiv
      08-16-2013, 11:00 PM   #22
ZTUNER
21
The fmic will definitely help. I don't know about shiv's tune but in the Cobb tune if your water temp is over 200f and your sits are over 120f you start getting timing corrections. The higher the Ait the bigger the corrections. There is a timing reduction cap however it can reach as high as 6.5 deg in certain conditions. IMO if you just did fmic it would help a lot. Another thing to do is to get rid of the dp cats. That should take some heat out of the system, not sure how much that will affect timing. I have not done that but in theory it should help.
After extensive logging I feel all tunes are quite aggressive. It's either that or maybe I am too conservative
Harry
