Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > E92 TPS light on what could it be? (pressure is good)
      08-15-2013, 01:46 PM   #1
gabster
11
Drives: e92
This is the messege i get on the dash, yes i checked all air pressure its all to spec and reseted the TPS and still get this
its a 2007 E92 328i 70k miles OEM wheels and tires.
what could be wrong??
thank you guys for your help
      08-15-2013, 04:29 PM   #2
gabster
11
Drives: e92
can somebody please move this to the right place if I'm on the wrong place
thanks
      08-15-2013, 09:42 PM   #3
notnow
Bit by Modbug
258
Drives: F86
In my other car when my brake pads were required to be replaced, I got the same message. My brake pads were so bald that it required a lot of brake fluid to keep it working, and I believe the low brake fluid level caused that message. After changing fluid and brake pads, message never came back.
      08-15-2013, 09:49 PM   #4
infidel335
infidel335's Avatar
29
Drives: 2009 335xi
It could be a low battery.
      08-15-2013, 11:01 PM   #5
Seanpatio
Seanpatio's Avatar
187
Drives: 2022 BSM F90 M5C
Reset them that usually works.
      08-16-2013, 09:04 AM   #6
gabster
11
Drives: e92
i did reset them after checking the pressure, and nop, light still came on
      08-16-2013, 10:17 AM   #7
Projekt_BooGie
Average Car Exceeding Expectations (ACEE)
Projekt_BooGie's Avatar
358
Drives: 2007 335i e92
2007 e92  [7.00]
the sensor could just be bad
too much to list...just know its wide and bagged
      08-16-2013, 06:19 PM   #8
khaye1
khaye1's Avatar
Philippines
145
Drives: 18 AW F80
Time to get new sensors...your car is an 07 and that's about the right time for replacement sensors
