Open Flash Tablet - Stg 0 Datalog
08-13-2013, 08:59 PM | #1 |
64
Rep 553
2007 E90 335i
80,000 miles AT DCI, 7" VRSF FMIC, Secondary CAT delete, RB PCV Valve 93 Octane Stage 0 Open Flash 3rd gear pull WOT. About 75 degrees out. How does this log look?
Montego Blue E90 335i
7" VRSF IC | OFT Tune | DCI | RB PCV | Secondary CAT Delete & CYBA 3.75" Tips | M3 Front | Mtech Rear | CSL Trunk | 219M | KW V1 | AA CP Last edited by kfrazie1; 08-13-2013 at 09:05 PM.. |
08-13-2013, 09:05 PM | #2 |
1740
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Timing, boost and throttle look great but your fuel trims are maxing out in the midrange which is something that I have not seen with any Stg0/Stg1 logs. Are you still running stock LPFP? Are you getting any other code that would suggest fuel pump issues?
Have you been running ethanol mixes? |
08-13-2013, 09:08 PM | #3 |
64
Rep 553
Always run 93 octane. Never ran any ethanol mixes ever. Never had any codes related to fuel pump and I check regularly once a month. LPFP is stock.
7" VRSF IC | OFT Tune | DCI | RB PCV | Secondary CAT Delete & CYBA 3.75" Tips | M3 Front | Mtech Rear | CSL Trunk | 219M | KW V1 | AA CP |
08-13-2013, 09:17 PM | #4 | |
1740
Rep 17,960
Drives: A Lot
Shiv |
08-13-2013, 09:23 PM | #5 |
64
Rep 553
Original LPFP that I know of. I've owned the car since 54,000 miles.
What is the fix for maxed out fuel trims? Is this basically robbing power? Thanks for the support!! I will send over my file.
08-13-2013, 09:29 PM | #6 | |
1740
Rep 17,960
Drives: A Lot
Shiv |
08-14-2013, 10:49 PM | #7 |
64
Rep 553
After troubleshooting with Shiv, looks like my fuel trims even on the stock tune are maxing out during a 3rd gear wot pull. Looking for any good recommendations for troubleshooting. Was thinking of swapping out LPFP first. Below is the datalog for my stock tune.
7" VRSF IC | OFT Tune | DCI | RB PCV | Secondary CAT Delete & CYBA 3.75" Tips | M3 Front | Mtech Rear | CSL Trunk | 219M | KW V1 | AA CP Last edited by kfrazie1; 08-15-2013 at 06:29 AM.. |
08-16-2013, 11:21 PM | #8 |
64
Rep 553
Did some more logging with the bavarian tech tool on my stock tune to look at LPFP pressures and fuel rail pressures. I believe my LPFP pressures are on target at about 72 psi +/- 2; however, my fuel rail looks to be dropping pressure from 2600 psi to 2000 psi while WOT. Maybe I have an HPFP problem. Not showing any codes though. Anyone know what pressures trigger HPFP codes? I've never had any signs of a bad HPFP...
08-17-2013, 01:03 PM | #10 |
184
Rep 2,841
If your LPFP pressure is pegged at maximum (72psi), that can be a sign of lpfp sensor failure.
I beleive it defaults to maximum pressure by default when it fucks up. when that sensor fails your low pressure fuel pump will be commanded on at 100% duty cycle, giving you maximum fuel delivery to your high pressure fuel pump at all times. |
08-17-2013, 03:26 PM | #11 | |
64
Rep 553
08-17-2013, 03:31 PM | #12 |
64
Rep 553
Well, I decided to reset some adaption values. I reset secondary air, throttle adaptions, Air Fuel Ratio, intake manifold, and air control using the bav tech tool. Then I drove it around for 5 miles. I decided to also clean the T-MAP sensor and manifold MAP sensor with some electronics cleaner. Soaked them preety good since they were coated in oil.
I ran another log of a 3rd gear WOT run on my stock tune and it appears the my fuel trims are stabilizing. This may change after the car adapts but hopefully not.
08-19-2013, 07:01 PM | #13 |
64
Rep 553
08-19-2013, 07:03 PM | #14 |
1740
Rep 17,960
Drives: A Lot
08-19-2013, 07:04 PM | #15 |
64
Rep 553
I went back to the original stage 0. Should I switch to the revised one?
08-19-2013, 07:06 PM | #16 |
1740
Rep 17,960
Drives: A Lot
No, i think you are fine with the standard file. Also I think you are plotting fuel trim bank 1 and fuel trim bank 2 with different max/min scaling values. Which makes them look unequal. Or at least that is what it appears.
08-19-2013, 07:14 PM | #17 |
64
Rep 553
I think the scaling is the same. Fuel Trim for bank 1 is a bit higher.
Thanks again Shiv for the support
08-19-2013, 07:21 PM | #18 | |
1740
Rep 17,960
Drives: A Lot
All you need to do is click on the channel name in the bottom left hand window and press the letter "P". Make sure autoscale is off and then set both trims so that they range from -40 to -40 as it was in the default settings. This will be good for your viewing pleasure. |
08-19-2013, 07:43 PM | #19 |
64
Rep 553
08-19-2013, 07:45 PM | #20 |
1740
Rep 17,960
Drives: A Lot
08-19-2013, 08:31 PM | #21 |
Rep 45
Wow Shiv you sure go out of your way to help everyone. I know its your business and all but the extra mile is impressive. I am new to the platform and was a little put off by how unprofessional a lot of vendors are on here.
I also have read enough between this forum and others to see how much flack your getting and its sad to see. I will say this. Keep doing what your doing and it will all play out. You offer not only good products but also you back them up with knowledge and good customer service. Don't let others bring you to their level. They seem to be desperate. Customers want quality products, good service, and professionalism. Thank you Last edited by Surferboy; 08-19-2013 at 08:32 PM.. Reason: forgot something else |
