F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Track wheels/tires... wider or lighter?
GetBMWParts
      08-13-2013, 09:50 AM   #1
DVC
Diligentia Vis Celeritas
DVC's Avatar
558
Drives: 335i
I'm considering a few options for wheels/tires, and would appreciate advice from experienced track drivers. These will serve double duty as DD and occasional track use, and I would prefer to stick with a 19" setup unless it's a significant compromise on the track.
The plan is to go with a square setup.
In terms of width, would I be better off squeezing a 9" wheel up front at the expense of a few pounds of unsprung weight per wheel? From what I've read, when it comes to grip, width of the wheel is more important than tire tread width (i.e. a 245 versus 255 tire on an 8.5" wheel makes little to no difference, but either tire on a 9" wheel will provide more grip), but weight is also certainly a strong consideration...
So which is more important?
Ahead of the curve for specF30
      08-16-2013, 10:23 AM   #2
DVC
DVC's Avatar
558
Drives: 335i
Anyone?
      08-16-2013, 03:28 PM   #3
JMK007
67
Drives: 335 M Sport, RWD
19" are a bit tall and heavy. I think 245/40/18 are ideal. I like my Apex Arc 8s; 18x8.5 are a nice size. Contact jbass on this forum if interested.
      08-16-2013, 03:30 PM   #4
DVC
DVC's Avatar
558
Drives: 335i
8.5 or 9"?
      08-16-2013, 03:32 PM   #5
JMK007
67
I have the 9" but that is a bit wide for anything under 245.
      08-16-2013, 04:05 PM   #6
DVC
DVC's Avatar
558
Drives: 335i
So you felt like the extra wheel width was worth the weight penalty?
      08-17-2013, 12:36 PM   #7
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Check out jbass's Apex ec7 thread in the wheels section. The 9s will rub in the front.
      08-17-2013, 06:21 PM   #8
DVC
DVC's Avatar
558
Drives: 335i
Depends on camber and offset. A lot of guys are running 9s up front (without fender rolling) with no rubbing.
      08-17-2013, 06:50 PM   #9
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
My car is very low and it's only rubbing a little on the fender liner, not the fender.
More negative camber probably wouldn't help but it would allow a 255 in there!!
      08-19-2013, 10:50 PM   #10
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
More selection of tires in 18" as well.
      08-29-2013, 10:55 AM   #11
DVC
DVC's Avatar
558
Drives: 335i
OK, I pulled trigger on a set of Apex ARC-8s in 18x9 et42 in satin black. At 18.65# per wheel, I am willing to stick with 18s. The more I learn, the more it seems that 18s are the way to go for performance anyway; 19s are for boulevard cruising.
      09-03-2013, 12:43 PM   #12
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
Let's see 'em!!
      09-03-2013, 01:51 PM   #13
DVC
DVC's Avatar
558
Drives: 335i
Originally Posted by jbass524 View Post
Let's see 'em!!
Just got confirmation today that they arrived at the shop. Which is exciting... but it will be more exciting when the car arrives
My 2014 335i should be delivered in a week or so; once I pick it up, I'll get the wheels installed and post some pics.
      09-03-2013, 08:11 PM   #14
ronin951
ronin951's Avatar
44
Drives: 2013 328i M-Sport
Same setup here. I'll post some dirty pics tomorrow with m perf brakes and suspension. Get your wallet out lol
2013 EBII 328i M-Sport 6MT, M-Performance Brakes, M-Performance Suspension, APEX Arc-8 18 x 8.5 square, Pilot SS
1999 EB1 M3 - Bilstein PSS9, Vorshlag Camber Plates, Kosei K1, ZII Star Spec, PFC, gallon of distilled water.
      09-11-2013, 03:23 PM   #15
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
Guys I'm new in the tire sizes stuff, but I crossed on the internet with these camber tires, I have a 225/50 R17 7.5" front and 255/45 R17 8.5" rear but they only have 245/45 and I don't know if it will fit in the front..so I contact camber tires and he (John Scott) said it might he has to see the car but I live in Egypt anyone have tried 245 in the front ?
      12-02-2013, 09:38 PM   #16
DVC
DVC's Avatar
558
Drives: 335i
Let's see 'em!!
@jbass524, I finally snapped a couple of pics with the new ARC-8s on the car...
      12-03-2013, 09:37 AM   #17
JMK007
67
Looks good!
      12-03-2013, 04:09 PM   #18
utenigma
162
Drives: 2013 F30 335i 8SA M-Adaptive
looks nice
IMHO you should pop-out the APEX center caps and put the roundel ones back in - they'd touch off the black wheels with the blue paint and blue calipers nicely
      12-03-2013, 04:47 PM   #19
DVC
DVC's Avatar
558
Drives: 335i
Originally Posted by utenigma View Post
looks nice
Thanks! Re: the center caps, I am usually not a fan of the roundels on aftermarket wheels - particularly black wheels. But you do make a good point about the blue calipers... might have to give that a try.
      12-06-2013, 05:32 AM   #20
Vitoco
Infidel
Vitoco's Avatar
122
Drives: iX3 LCI M Pro Carbon B
My winter wheels are also black and look similar to yours + I got the M brakes also, I too am not a fan of putting the roundel on aftermarket... but I´m considering it cause it does look better breaking up the black.
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022
| Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts |
      01-03-2014, 11:59 PM   #21
shivaswrath
shivaswrath's Avatar
649
Drives: 2012 335i
You decided to not stagger then? How was it on the track?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      01-04-2014, 02:35 AM   #22
JN1
JN1's Avatar
301
Drives: S211 AMG E63
Exactly what I was going to ask.
I think I'm set on 18 x 8.5 +35 square for my dedicated track wheels, but deciding on tire sizing still 235 or 245
-JustinNApproved
f30post
