Engine malfunction. HELP !! 335i
08-12-2013, 06:54 PM | #5 |
19
Rep 379
Read the stored fault codes and post them here.
I am sure someone will able to help you if you provide more technical information.
********** 2008 BMW 335i TT******
08-12-2013, 07:10 PM | #7 |
Rep 36
Definitely sounds like the flux capacitor. I've seen the exact thing happen before. It tends to act up at around 88 MPH. If you can put a volt meter on it, it should read exactly 1.21 Jw. A little more or less and you will have problems.
08-12-2013, 07:13 PM | #8 |
77
Rep 439
Obligatory: don't drive that fast on public roads.
You're in a pretty heavily populated area, try to see if you can find someone who can pull the codes for you if you're not getting anything from a normal OBD reader. Until you know what the issue is, stay clear from those speeds. There are so many different things that could be causing that error. For me it was a boost error. That doesn't appear to be the issue for you or else I imagine you would be seeing it more frequently than only going in excess of 100mph. |
08-12-2013, 07:15 PM | #9 | |
Rep 302
08-13-2013, 09:22 AM | #10 |
1013
Rep 1,268
the car is protecting you from yourselves, you think the government is passing laws to keep you save well now your car is doing it for you as well. Welcome the the Nanny Car.
08-13-2013, 04:46 PM | #11 |
91
Rep 1,555
^this guy
