OpenFlash Tablet E30 OTS Map Testing (Datalogs Galore!)
08-06-2013, 01:10 AM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Hi guys,
I had an hour free today to actually get in a car and drive. So naturally I add 4.5 gallons of E85 and fill the rest up with 91oct, making E30. Then I took the current OTS Stg1 map and made some adjustments to AFR, fuel scalar, ignition advance torque limits, etc,. Basically the start of a Stg1 E30 OTS map for minimally modifed cars running E30 based upon some data points I logged from years of Procede testing. Then I datalogged a very spirited (and continuous) 15 minute blast through the Mexican canyons. I took a small video at the start of the run. The rest of the run is captured in the datalog below Car details: 2007 BMW 335i 6AT w/ 107,000 miles Mods: DCI-only Tune: OpenFlash Stg1 E30 beta map IJEOS ROM E30 Fuel Full Datalog below. Many 2-3, 2-3-4 and 3-4 upshifts. You can recognize the gear by looking at roadspeed (last log at the bottom of each screenshot): Zoomed in: So we are off to a good start. Most of the runs show very clean timing logs. Definitely within the allowance. Still much more testing to do. Both on the road and on the dyno. Still a couple weeks away from releasing any OTS E30 maps. But just wanted to share the data from tonights testing. I know tuners tend to keep their test results to themselves. But I think disclosing them is more fun Have a good night! Cheers, shiv |
08-06-2013, 03:00 AM | #3 |
184
Rep 2,841
Interesting!
Without meth those IAT's climb up.....is that why timing takes a hit on some of those logs? What torque limit changes did you make to which tables for these maps? |
08-06-2013, 06:51 AM | #4 | |
Leeeroy Jankins
31
Rep 423
e90 LCI w/ -= VRSF 7" FMIC =-
-= Cobb: Stg1 +FMIC Aggressive ST =- Last Install: BMS DCI + Caliper/Drum Paint "If you're not 1st, you're last" -Ricky Bobby |
08-06-2013, 07:06 AM | #6 | |
171
Rep 2,682
This has nothing to do with flexfuel. Besides, even the Procede has fixed E50 blend maps. The flexfuel mod is purely for those that wish to run whatever E85 mix they want and can't be bothered messing around with calculations and estimations. Also, flex fuel only works with a piggy and not any flash type of tune.
08-06-2013, 08:52 AM | #7 | |
184
Rep 2,841
But seriously.....with stock intercooler and downpipes/exhaust it would be normal for IAT's to climb that much and even more so. But my question was about what mechanism induces timing drops. The reason I ask is because there is a main timing table which sets the ignition values and I am trying to understand where the tune goes for failsafe timing values when parameters fall out of range. |
08-06-2013, 09:24 AM | #8 |
87
Rep 808
Awesome Shiv, the logs look good and that video shows the car is climbing through the gears FAST!
What kind of power output would you expect with this map and a DCI only car? |
08-06-2013, 09:59 AM | #9 |
456
Rep 6,478
Looks pretty good for a beta type map.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
08-06-2013, 10:00 AM | #10 | |
456
Rep 6,478
08-06-2013, 10:18 AM | #11 |
184
Rep 2,841
08-06-2013, 10:43 AM | #12 |
195
Rep 6,136
08-06-2013, 01:25 PM | #14 |
1737
Rep 17,960
Drives: A Lot
There are two IAT ignition retard tables. One is factor based. The other is max degree based. For e85 use, we modify them to be more tolerant of higher IATs since the TMAP doesn't see the in-cylinder cooling benefits of ethanol. I suspect the reduction in timing that happens from time to time in 4th gear has more to do with transmission control/trans oil temp.
08-06-2013, 01:35 PM | #15 |
335i Owner
57
Rep 839
Drives: BMW 335i 4 Door
The fact that this was tested on an 07 E90 6AT and my same ROM type makes me so happy! I already have 3 maps planned for when I buy the etune
E90 - 2007 BMW 335i Sedan
45K miles 7" VRSF FMIC | BMS DCI | AR Catless DPs | KW v2 Coilovers | M3 Front Control Arms |
08-06-2013, 01:39 PM | #16 | |
184
Rep 2,841
So does that mean that there is still yet another table hidden somewhere in the DME that intervenes on timing when the tranny gets out of sorts? My car does this once in a while too and I have always wondered about it. |
08-06-2013, 01:46 PM | #17 | |
1737
Rep 17,960
Drives: A Lot
There is communication between the TCU and the DME at all times. The TCU sends torque reduction commands to the DME. The amount of torque reduction (if any) depends on many things including trans oil temp. When trans oil temp goes above a certain temp threshold, it would appear that the requested torque reduction during shifts is more prevalent. This also would explain why it's more common when you do a 2nd to 3rd to 4th run compared to just a 3rd to 4th run. The extra gear change at the beginning means a higher oil temp by the time you do the 3rd to 4th gear upshift. This would also explain why you can reduce the frequency (or eliminate) this ignition retard by stacking tunes and making the DME (and TCU) see less calculated torque output since calculated torque output, like trans oil temp, must be one of the variables involved in the torque reduction equation. This is just my theory so nothing is proven yet. But it does make sense based upon what I've seen. I also remember noticing that 6AT cars with oil coolers are less likely to see this post-shift ignition retard. But more testing does need to be done for sure.... Shiv |
08-06-2013, 01:55 PM | #18 | |
184
Rep 2,841
08-06-2013, 02:50 PM | #20 |
324
Rep 2,014
This looks great! Shiv, do you have any plans for a racing gas map as well?
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
08-06-2013, 04:29 PM | #21 | |
177
Rep 6,631
no ill will intended. the issue im harping on isnt unique to Shivs OTS maps. it affects Cobb too. I just want to discuss possible solutions for the issue, with it being open source and all. |
08-06-2013, 04:38 PM | #22 |
1737
Rep 17,960
Drives: A Lot
The problem with your posts is that they are usually associated with another post, posted simultaneous on another forum, bragging about the aforementioned post and complaining about how "dumb" the people on this forum are. You're disingenuous and everyone here knows it. So please don't play games and waste everyone's time. I will start reporting your posts if you continue interfering with our threads. Same goes to e90company.
