Are my wheels suppose to fit??
08-01-2013, 01:00 PM | #1 |
34
Rep 252
So I just bought 4 new Matte Black Rota Grid Drift wheels for my car. They are 18x9.5 ET35. The backs fit just fine, but the fronts (the same size all around) don't fit just right. The front right wheel is fine, no rubbing. The front left wheel looks to be grinding against the shock when I make left turns. Anyone had this before?
08-01-2013, 04:41 PM | #2 |
287
Rep 1,710
Did you get an alignment done?
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod |
08-01-2013, 04:56 PM | #3 |
81
Rep 6,092
what size/brand tires are on there?
08-01-2013, 05:00 PM | #4 |
158
Rep 2,561
You basically have no strut clearance in the front and will need spacers. Your combination of offset and width makes it so that the barrel is too close to your shock, causing the sounds you are hearing. Get 5mm spacers for the front and you should be fine. Camber can affect it too, the more camber you have the closer the wheel comes to the strut. You shouldn't have more than like 1 degree of camber anyway, so go with the spacers.
Montego Blue 2007 E92 335i - ZSP / ZPP / Steptronic / Logic7 Broadway Static - CCW - Megan - Orion Instagram: bmwforlife |
08-02-2013, 01:25 AM | #5 |
34
Rep 252
08-02-2013, 01:29 AM | #7 | |
34
Rep 252
08-02-2013, 09:57 AM | #8 | |
163
Rep 2,823
Does the wheel/tyre spin without hitting anything, when the tyre is jacked up? Have you checked the back of the wheel is there any marks of it hitting somewhere? Also i find it weird that it only happens when you are turning. I think it should hit the shocks all the time, when driving, if it would hit the struts.
08-02-2013, 12:13 PM | #9 |
BimmerPost Supporting Vendor
2044
Rep 25,989
Hmm, I'd have your car checked out to make sure nothing is bent. It wouldn't make sense why one side would clear while the other doesn't.
You don't need an alignment when swapping wheels, but if you haven't gotten one in a while, perhaps now is a good time. Don't want to burn through those tires faster than you should!
VMR|Wheels | 714.442.7916 |
08-02-2013, 07:28 PM | #10 |
79
Rep 2,110
As stated above with that offset your inner lip is essentially hitting the strut. No an alignment wont fix this issue, the distance from the rim lip to the strut is fixed and non adjustable via an alignment, camber or toe wont change the clearance. You'll need a 3 or 5mm spacer to pull the inner lip away from the strut.
08-02-2013, 11:31 PM | #11 | |
163
Rep 2,823
08-03-2013, 01:42 PM | #13 |
34
Rep 252
I added a 5mm spacer on the fronts and haven't had issues. The right side was rubbing, but just enough to take the paint of the shock, the left side on the other hand had rubbed a little more. I was told that with coil overs, I should have MORE room since the shock is thinner. I don't know if that is true because I haven't got them in the mail and installed yet. So far, right now all is good.
08-03-2013, 02:04 PM | #14 | |
163
Rep 2,823
