Steering wheel hard to turn
07-30-2013, 01:22 PM | #1 |
BESIKTAS - cArsi
17
Rep 164
Hi Everyone,
I'm having a problem with my steering wheel when trying to turn, it is soo hard. I have to use both my hands. But it goes hard to normal hard to normal. I took it to a mechanic and he said it is the Lower Steering Shaft Joint Assembly that needs to be changed. The only reason I wanted to ask here is because I was reading someone having a similar problem and it ended up being the "universal Joint". I don't know if I trust this mechanic a lot. So I just wanted to get some opinions from you guys. Thanks in advance..! Last edited by BJK1903; 07-30-2013 at 02:18 PM.. |
07-30-2013, 01:58 PM | #2 | |
13
Rep 342
Drives: E90 Monaco Blue 335i xdrive
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
07-30-2013, 02:18 PM | #3 |
BESIKTAS - cArsi
17
Rep 164
08-12-2013, 04:09 PM | #5 |
977
Rep 3,875
Drives: 330i, 135i
Guys I noticed my steering is a little harder than normal, just a bit. I checked fluid and is low, its barely touching the low end of measure dip stick. Fluid looks normal in color not black at all. I wonder if I should change fluid or just add more?
Regardless, I will stop by the dealership and buy 1 quart of power steering fluid with my $40.00 coupon I still have succkkers!!! Aint coming from my pocket... |
08-13-2013, 04:53 PM | #6 | |
BESIKTAS - cArsi
17
Rep 164
Ok guys,
This is what i did. Bought a WD-40 and white lithium grease. Open your hood and spray the WD-40 all around the lower steering shaft over night. Just spray and turn the wheel and just keep spraying. In the morning you will notice that the steering wheel is just like new. Now open the hood and spray that white lithium grease and just keep turning the steering wheel. Leave it for an hour or so. It will fix it. At least it did mine. It's been about 2-3 weeks since I did it, and it still works like a charm. Saved my ass $600 :happy anim: Quote:
niksss10.00 |
08-13-2013, 07:53 PM | #7 | |
977
Rep 3,875
Drives: 330i, 135i
Thanks |
08-16-2013, 02:10 PM | #8 |
BESIKTAS - cArsi
17
Rep 164
08-16-2013, 02:14 PM | #9 |
977
Rep 3,875
Drives: 330i, 135i
08-16-2013, 03:47 PM | #10 |
226
Rep 2,387
Ummm if it was a u-joint this will not fix it, and the U-joint already may be damaged. Hate to have that let go under stress. Worth checking it out to make sure. I do not know what type it is but if it is sealed, and started binding, that means bad stuff is happening inside of it. Like CV joints once they begin to fail there is not much to do except replace them. Sure you could spray WD 40 into the boot but then what.
08-21-2013, 06:10 PM | #11 |
977
Rep 3,875
Drives: 330i, 135i
Yesterday I checked my Power Steering fluid and see how dark it was using a drop on a paper towell and looked clear, not dark at all. I know is low, so hopefully by adding fluid my steering wheel will get easier to turn.
CJuice14328i0.00 |
08-27-2013, 02:46 PM | #12 |
BESIKTAS - cArsi
17
Rep 164
Sorry guys,
I really got caught up with work and business traveling this past week and couldn't add the picture. I'm not sure if I can do a DIY tho. But I promise I will add the pictures this week. ajsalida, I'm not claiming that this is the "Fix" or anything like that. I applied it to my car after I opened this topic, and since then I had no problems. It did save a ton of money. So if it's going to help someone and have this as a "workaround" till they have the money, or time or whatever, I'll post it. Isn't the forum here for that reason anyway? To share? Like I said, it is just a "workaround" till you have the time or money to get it fixed. But so far it worked like a charm for me. |
11-25-2013, 08:25 AM | #13 | |
Rep 52
11-26-2013, 06:56 AM | #14 | |
BESIKTAS - cArsi
17
Rep 164
Let me know how it works out. I was going to post pictures but I keep forgetting. Sorry guys. |
12-07-2013, 01:15 PM | #15 |
37
Rep 257
My 2011 335 xDrive 's steering wheel is very hard to turn at low speeds and when parking the car. It's extremely hard to park the car and have to go very slowly into a spot so not to hit other cars. I have to put a lot of muscle into it when parking. Is this normal? I just bought this CPO car with 23k mi. on it. Should I go to the dealer, or is this the way it's supposed to be? It doesn't appear normal to me that you have to put so much effort to steer a $55K (sticker) car at low speeds like that. My wife moved the car the other day because I was blocking hers in the driveway and she said "how do you drive that car? I couldn't steer it". I called the BMW Dealer I bought it from, and they said it's normal but bring it in if you want. Only problem is they are 50 miles away and I don't want to drive there for nothing if it's normal.
Thanks, Harry |
12-07-2013, 05:15 PM | #16 |
34
Rep 1,093
I've not verified this myself (However similar procedures are used on 4WD) but if you have a jack I would try this. From what I've read the front axle disengages when parked. Jack up the front and turn the wheel left or right and then spin each front tire to check for binding. If it binds up it's the CV's if not it is probably an issue in your Steering Column. The U joint does not appear to be serviceable and it is always recommended to replace them at first sign of failure. If a cap separates and the joint fails you world have no control. While it's in the air I would check for play in the front end most times these types of issues put a lot of strain on tie rods and other components and you'll want to confirm that they are in good condition.
Let me know if this procedure is possible on these cars. I’ve yet to have the wheels off the ground on mine. I do have brakes to do in the spring though I hope your issues are resolved before then. Greg
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
05-19-2014, 10:23 AM | #17 | |
398
Rep 4,084
7/18/09- I pick up my baby- 2009 E92 335i Xdrive, Space Gray over Coral Red. Premium Pkg, Cold Weather Pkg, M-Sport Pkg, 193Ms, Gloss Black grills, Custom Gloss Black Mirrors, Performance shift and E-brake boot, M3 spoiler, Euro fog switch, gloss black interior tim, Coco-Mats (red/black), H&R coilovers, 19'' Alufelgen SF-71s......
05-28-2014, 09:54 AM | #20 |
37
Rep 257
They replaced the lower shaft/joint assembly a few weeks ago after 3 visits and a lot of complaining. I also had developed a clicking sound in the steering wheel. However, the steering is still hard (sound is gone), if not harder, so nothing changed there. I also have a lot of slop in the steering wheel. So something else is wrong as well.
2011 Space Grey 335i xDrive E92, Sport Pack/Premium/Winter/Navi rolling on 342's.
2019 Accord Sport 2.0T 10-sp. |
06-05-2014, 09:06 AM | #21 |
19
Rep 128
I had dealer replace my lower shaft/joint assembly also before I took delivery of the car few years ago, it was really hard to turn during test drive. It was "binding" according to the dealer but it barely made any difference. Could it be our power steering pump is failing or has failed?
01-07-2016, 01:00 PM | #22 | |
Rep 1
