15 Min metal vaccum canister DIY
07-30-2013, 12:02 AM | #1 |
DIYER
614
Rep 5,521
Decided to do a small right up on this easy to do mod. I am sure many of you have done this...this is for those who havent. Such a easy thing to do and gives you piece of mind. The intake nipple can easily crack and leak causing your wastegates to not function correctly. Dealer broke mine 2X.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-31-2013, 05:22 PM | #3 |
DIYER
614
Rep 5,521
No flame suit, honest question. It is to replace the plastic nipples with steel ones on the vacuum (when looking on left they are the front right side of motor).
06-14-2014, 01:30 PM | #5 |
DIYER
614
Rep 5,521
ROFLMAO!
06-14-2014, 11:00 PM | #6 |
21
Rep 578
Drives: 2009 335i xDrive coupe
BMW has fucked me so much that I take it with no lube now. My service adviser "Ken" calls me his little butt slut and he makes me feel dirty and vulnerable.
07-17-2014, 03:58 PM | #8 |
DIYER
614
Rep 5,521
It was right at the base of the nipple. Push on nipple and you WILL see them.
08-10-2014, 10:43 PM | #9 |
184
Rep 1,364
I'm laughing so hard right now
2010 E92 335xi FBO 6-speed (Space Grey over Tobago Blue)
2006 E90 330i 6-speed (Arktis Blue over Black) 1984 E23 733i 5-speed (Delphin Grey over Pearl Beige) |
06-20-2015, 11:17 PM | #10 |
74
Rep 252
Just bumping this awesome little DIY. I found a nipple on a cannister was coming off. I have hot glued as an interim fix hopefully that will work for now and will do the fix above next week. Thanks for the write up Rob. Is there anything on your ride that you havent modded?
08-25-2015, 09:17 PM | #11 |
27
Rep 158
Thanks for the write up Rob! I'm modding mine this weekend as one of my can barbs bit the dust and who knows how the other three are actually doing... Figured this mod is way better than speanding $40 a pop to just buy something that is going to break again.
I've changed out both solenoids, replaced all vac lines and was hoping my rattle would settle down or go away. Could my lack of one canister(bypassed straight to solenoid) cause boost issues(lag or off target) & rattle? Side question & sorry to thread jack, but If I adjust the rear wastegate rod, I loosen the nut & turn the rod toward the fender to tighten for rattle correct? I may need some RB Turbo upgrades soon... wife is going to kill me! |
08-27-2015, 10:47 PM | #12 |
12
Rep 290
for the lazy:
http://www.mscdirect.com/product/details/01045376 Or you can acquire them at your local tool store. |
04-18-2016, 05:36 PM | #13 |
14
Rep 128
What side effects/draw backs does deleting the whole vaccum cannister have?
I was considering deleting( completely removing them) , and trying them for a week before I do the mod in the weekend. Would really appreciate quick answers So sick of driving around with two broken cannisters for the past few days..
________E90 335i 6MT mHD, VRSF DP, VRSF 7" FMIC, SSK, TWM knob, BAddictions DLB, CSF Rad, Rattling Turbos
04-23-2016, 02:42 AM | #14 |
Rep 117
pretty sure you mean 1/8 NPT, 11/32 sounds like the size for a 1/8 NPT tap.
07 A/W 335i 6AT/JB4/race BEF/FSB METH CM5/VRSF DP/DCI
