Faults in modules as a result of coding?
07-23-2013, 09:15 PM | #1 |
164
Rep 401
Hey guys, I'm pretty new to coding but have successfully coded many functions in my 2007 328xi without any errors. Car also has a fresh battery that is only about 2 weeks old (I replaced due to age and also due to multiple errors stored in various modules). However, while diagnosing a faulty radiator fan today (bearing is failing) I decided to randomly plug in my BT tool and scan all modules again (I typically do this once a month to monitor the car's health). I pulled many of the same codes again and nearly **** myself. Here is the list:
DSC related 5EBA - this is related to the steering angle sensor and a common issue. I'm going to clean the optical disk next weekend D35A - DSC: No message (CAS 304) CAS A0B4 - Fault engine start starter (car has always fired up without issue. One or two times it didn't crank the first time, but I attributed it to me hitting the start button before I had depressed the clutch completely...so chalked it up to being in too much of a rush and my lack of coordination). Instrument Cluster A3A9 A3B2 A3BD (all CAN ID related errors) 931B - Outside temperature sensor (not worried about this, going to check resistance of the sensor later this evening and check wiring) 931A - Signal tank raw data filling level right (I've gotten this error intermittently for ages, so not worried. Someday I will inspect the sending unit and harness in the fuel tank) MOST/CAN gateway A169 - IPC operation error E184 - CAN high/low-line error E194 - No CLAMP_STATUS via CAN received Telematic control module D690 - Ring breakage diagnostics was performed (Error_Ring_Diagnose) So...overall...my question is if simple coding could cause a series of all of these errors, or if it is simply a coincidence that the first time I have pulled the majority of them was after the car had been coded. The car runs and drives 100%, all coded functions work as they should, and no error lights are in the dash. My primary concern are the CAN related codes. Have any of you guys ever experienced something like this? |
07-23-2013, 10:37 PM | #2 | |
555
Rep 1,244
Drives: 2013 F10 M5
When I replace a battery, first thing I do is to register it, second thing is to scan and clear all faults in the modules after starting and running the car for a little bit. |
07-24-2013, 03:40 AM | #3 |
37
Rep 252
Don't worry about this if all is working fine, maybe these are an old errorr or maybe these errors appeared because you were coding with engine on?
Clear all the codes and after few days check them again, if some will show up it means that something is wrong and you can try to fix it. |
07-24-2013, 10:26 AM | #4 | |
164
Rep 401
07-24-2013, 10:35 AM | #5 | |
164
Rep 401
07-24-2013, 07:04 PM | #6 |
164
Rep 401
Rescanned tonight...codes haven't returned (likely too soon) but now I have a new one for the junction box...C90B, Communication PT_Scan. Considering this one was junction box related, I am going to pull the glove box out so I can access the back of the fuse box and inspect BMW's work in performing the battery cable recall. I am wondering if there is a chance that not everything got plugged back in securely or if insulation on a wire or two got pinched/stripped. Throwing codes left and right like this is completely unacceptable and never happened prior to having the recall performed and/or coding.
09-22-2013, 04:39 PM | #7 |
Rep 144
Drives: '08 BMW 335i Coupe (MT)
Hey just wondering if you ever resolved your issues with these random module faults? I have several similar faults and I believe they are related to Battery needing replacement or Battery Cable Recall.
Haven't performed either yet, but did put battery on slow overnight charge and Date/Time hasn't reset for a few weeks now, but I continue to get these codes even after clearing them using BT Tool: A559 - Clamp 30g_f cutoff A6CF - Sensor AUC E18C - Device didn't accept or confirm monitoring message E18F - Central registry does not match w/debit configuration D690 - Ring breakage diagnostic was performed Everything seems to be working properly. I did reseat a JB3 connection while the ECU was "awake" which I suppose could also be the culprit, but you'd think clearing the codes once would be sufficient. About to install JB4 and would like all modules to be free of issues first. |
09-25-2013, 04:14 PM | #8 | |
164
Rep 401
10-02-2013, 02:00 PM | #9 |
Rep 144
Wow, that's pretty sad. Good to know you were able to fix the issue without sinking a bunch of $$ in to it though.
Thanks for the info. I will try to find a reputable dealer to handle my Battery Cable Recall but will def be checking their work afterward. |
10-02-2013, 05:01 PM | #10 | |
164
Rep 401
They also broke my cupholder then claimed it was already broken when I brought it in. And people wonder why I do ALL of my own work. You can't trust anybody anymore |
