07-23-2013, 08:40 PM | #1 |
27
Rep 444
First tire change on the M5!
So just wanted to get everyone's view on the best tires and size to put on the m5! Not sure if I wanna jump up in size with my stock rims but I do love the PSS, Any other options that people like?
07-24-2013, 01:35 AM | #3 |
48
Rep 434
I agree with Grayblack and PSS is the way to go. I had Falkens and I didn't like them although they were briefly on my 21s. Look through the Board since you may qualify for the Michelin guarantee if your treadwear is less than a certain mileage.
07-24-2013, 05:50 AM | #5 |
Rep 222
Drives: '12 BMW M5 Alpine White
What mileage did you make it to before requiring new tires?
07-24-2013, 07:38 AM | #6 |
Live for today tomorrow never comes
1989
Rep 9,498
[/B]+ 1
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
07-25-2013, 01:14 AM | #8 |
20
Rep 273
07-26-2013, 01:01 PM | #10 |
2870
Rep 7,885
Any idea when Niko?? I'm in the same boat as you.
07-26-2013, 01:37 PM | #11 | |
48
Rep 434
Current ///M: '13 F10 M5, Sapphire Black, Eisenmann Race Exhaust, CF Delete, H&R Sport Springs, iND Cosmetics, Escort 9500ix hardwired, 21" Vorsteiner VFF-103 w/Michelin PSS, RKP Front Lip, Challenge Rear Diffuser, M Illuminated Door Projectors, and LCI M Performance Black Grills
'15 i3 BEV |
07-26-2013, 03:06 PM | #12 |
19234
Rep 10,145
305's on a 10 inch wheel is not optimal- it should be on an 11.... you guys can do it but its gonna have some carryover. And PSS's run square already on the sidewall.
But as Jose posted above they are here stateside.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
07-26-2013, 07:34 PM | #13 |
152
Rep 3,041
I think the recommended wheel size fro 305 PSS is 10"-11". I know in researching my new wheels the contact patch is the same in a 10.5" vs 11". You will get some sidewall stretch in the 11". I have them on my F10 in 21". I am not sure I would go 10" though. Prob. min. of 10.5" just because of the square sidewall.
07-26-2013, 07:34 PM | #14 |
177
Rep 1,155
That's one good reason to go with the style 601M with the comp pak for new buyers -- 10.5" width will work better with a 305. Glad to see they finally made it over here.
What do you mean by "carryover"? |
07-27-2013, 07:49 PM | #15 | |
67
Rep 704
07-30-2013, 07:06 AM | #16 |
53
Rep 563
I'm definitely looking at the 305 30 20 setup when I need new shoes for my stock 20x10 wheels. Doing the math, the 305 is .4" wider and .23" taller. In fact the 305 30s give you the same sidewall as the stock 265 35 20 front tires. The stock rear 295 30 20s are actually shorter than the stock front tires.
Vic has a good point (as usual) that it may not be optimal, however Micheline does rate the 305 30 for a 10" rim. All that said, I think the .2" (+.4" section width /2) on each side of the rim will offer slightly more rim protection from curbing while still providing a nice filled in yet square look. Also the extra tread width should help with traction. Now I just need one of you brave souls to try the 305s out for me and post a review with pics! |
07-30-2013, 10:03 AM | #17 |
48
Rep 434
For those running 21s you can install Michelin PSS 265/30 and 305/25. That is what I'm running now with wheel sizes 9.5 and 10.5. You just need to make sure your offsets are just right.
07-30-2013, 10:11 AM | #18 |
1989
Rep 9,498
Which are?.
07-30-2013, 11:34 AM | #19 |
48
Rep 434
This is a "cut and paste" from the invoice I received from ADV1 to replace one rear wheel from an accident (not my fault) I got into recently. As you can see, unfortunately it does not include the offset information. If you have 21s or thinking of getting 21s, then I suggest you contact Ben @ Wheels Boutique. He'll know the correct offset!
Vehicle Year: 2013 Make: BMW Model: M5 Wheel Style: ADV08 Configuration: Track Spec SL Series Upgrade y/n: Y Hardware spec / finish: Exposed Brakes Oem / Aftermarket: OEM Backpad Pocketing y/n: Center Bore: Notes: Replacement wheel for damaged rear wheel off original set. Submitted with picture of damage to match fasteners and finish. 0.00 0.00 3 Piece Forged | Track Spec Contoured Profile | ADV08 SL | 21.0 X 10.5 1 2,400.00 2,400.00 Center disc finish: Brushed w/ Single Dark Tint w/ Clear 1 100.00 100.00 3 Piece Lip Finish: Polished Aluminum w/o Clearcoat 1 0.00 0.00 3 Piece Inner Finish: Standard Single Tone | gloss gunmetal 1 40.00 40.00 Center Cap: ADV.1 Standard Aluminum cap | Finished to match wheel 1 0.00 0.00 Ground shipping - Domestic 1 50.00 50.00 Engineering: Repeat File 3217W (Rear Wheel) 0.00 0.00 0.00 0.00 $2,590.00 $0.00
'15 i3 BEV |
