How to remove: Black plastic - Trunk bottom
07-23-2013, 05:54 PM | #1 |
Montreal R-Spec
17
Rep 180
Quick question guys before I hit the track this evening. Is there a special way to remove this part? After removing ten 10mm screws.. 4 on top, 4 on bottom, 1 on each middle side. The left side seemed to come off easily, but the right side is giving me much difficulties. Am I missing another screw or bolt somewhere?
MARK ALEXANDER
▀▄ 'O6 330i | 6MT | Sport Package | Black Sapphire Metallic | Aluminum Trim | Black Dakota Leather | H&R Sport Cupkit | AFE Intake | Matte Black (Dipped)162's - BFGoodrich g-Force T/A KDW | 18mm Rear Spacers | ECS CF/Aluminum Strut Bar | M3 Sways | Depo Blacklines | |
07-23-2013, 05:56 PM | #2 |
1052
Rep 5,660
How much does it weigh?
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
07-23-2013, 06:02 PM | #3 |
Montreal R-Spec
17
Rep 180
According to the Weight Reduction Compilation Thread -> http://www.e90post.com/forums/showthread.php?t=627141
It`s 9.6lbs. (thick piece of plastic) I also removed. Rear Seat- Back: 40lbs Rear Seat- Bottom- 14lbs Battery Cover (With Tools): 3.1 lbs Trunk Lining (both sides) plus rear plastic piece- 5.2lbs Interior Trim Pieces- B Pillar and door flooring- 3.8 lbs Easily Removable Seat Belt Pieces- 6.8 lbs Hood Cowling, Cabin Air Filter, wire holder, ECU Cover (Missing ABS Cover)- 10lbs Front Sport Seats- 65 lbs each Trunk Insert- 1.5lbs Measily 30 mins to remove it. Quick, easy, fast extra weight to remove.. except..... Back to my question please
MARK ALEXANDER
07-23-2013, 06:24 PM | #4 |
Montreal R-Spec
17
Rep 180
Anyone?
MARK ALEXANDER
07-23-2013, 06:40 PM | #5 |
Beamer Mantic
82
Rep 1,191
2006 325i
2006 M5 2008 X5 4.8i 2014 X5 50i M-Pkg |
07-23-2013, 07:28 PM | #6 |
Where'd my VTEC go?
481
Rep 6,067
did you remove everything connecting to it on the bottom? there are plastic splash guards and a bumper structural support piece that screws to the bottom.
are you going to cover it up with something? not sure how it will affect aerodynamics with a gaping hole in your trunk floor...
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
01-28-2018, 08:21 PM | #7 |
68
Rep 763
Drives: BMW E90 Dinan stage 3 335I
Trunk cover piece
2007 E90 335i N54 Montego blue with grey Dakota leather interior
