Can't Reset Oil Service
07-21-2013, 04:17 PM | #1 |
17362
Rep 18,756
So the strangest thing. Today I just changed my oil for the 13th time and I can't get the CBS to reset the oil service indicator; it still shows I'm due for an oil change in 500 miles. I tried resetting it using the BT Scan tool and using the stalk. The last 3 or 4 oil changes my BT scan tool won't reset anything on the CBS and I have to go with the stalk method.
As additional info, last oil change I did back in April when I reset the CBS (using the stalk method) the service interval only went out to 10,000 miles, which it usually counts up to around 18,000. Then the engine went a quart low a bit earlier than expected at 7,200 miles and when I added in a quart the E-dipstick showed the engine still a 1/4 quart low. The E-dipstick has been consistently been showing a shorter mileage interval when the 1QT+ symbol comes up. The when new the engine used to go between 16,000 and 17,000 before it went a quart low. Then it started dropping to 13,000, then 11,000, then around 9,500 miles until it hit a quart low. The car has 221,000 on it so the engine starting to consume some oil doesn't really concern me too much. The OCI this time was 9,700 vs. the normal 17,500 it usually goes. And lastly, I noticed that the e-dipstick has also not been instantly reporting a full compliment of oil in the sump after I change it and refill with 7 quarts. With this oil change today and the one in April, it took several readings and over 10 miles of driving for the e-dipstick to show a full reading; all the other oil changes before showed a full oil quantity on the first read once the engine warmed up. Strange. I'm thinking a new e-dipstick sensor is in order, what do you guys think? Last edited by Efthreeoh; 10-08-2020 at 05:49 AM.. |
07-23-2013, 03:05 PM | #3 | |
17362
Rep 18,756
I think I'm going to change out the sensor and see what happens. I may stop by a dealer and see if I can get a Tech to chat for a bit. |
07-24-2013, 03:12 PM | #5 |
12
Rep 656
Download a previous version of the BT software. This happened to me and I contacted BT. They confirmed an issue with their latest version.....
I was able to use the manual method with some playing around with the steps.... I couldn't confirm because I already reset it but they had me install 1.8.6.0. Last edited by jzchen; 07-24-2013 at 04:52 PM.. Reason: Checked which version they had me install. |
08-17-2013, 08:03 AM | #6 |
17362
Rep 18,756
So I'm bumping my thread here. I will be installing a new oil level sensor today with the hope it solves the problem. My thought is the sensor has slowly been degrading over time and now is at a point where the oil condition part of the sensor does not recognize a new load of fresh oil and is preventing the CBS from resetting.
The sensor level reading behavior has changed over time, where when in its younger life (remember my car has 225K on it it) it would instantly read "full" upon an oil change (after the proper engine warm-up time). The last two oil changes it has taken several attempts to finally read "full" (like 20 minutes of driving time). Secondly the sensor has been indicating partially low oil levels at far less miles than before when it was ; I'm sure the engine at 225K miles is consuming oil at a faster rate then when new, but I'm talking it would take 10,000 miles to read a 1/2 quart low, which recently has dropped to a full quart low in 9,000 miles. I'll report back in later today with the results. |
08-17-2013, 08:53 AM | #7 | |
103
Rep 2,783
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
08-17-2013, 09:01 AM | #8 |
17362
Rep 18,756
08-17-2013, 09:04 AM | #9 |
103
Rep 2,783
Thanks!!!!
08-22-2013, 10:37 PM | #11 | |
Rep 38
10-02-2013, 04:59 PM | #13 |
16
Rep 78
CBS Oil reset
I now have the same issue. BT enthusiast tool tells me that:
Control module responded with "Conditions are not correct" this can be caused when there is a fault stored in one of the related systems But, but, I checked and don't have any faults !! Was able to reset my brake fluid CBS today, but not the oil, so I know my unit is still operational.. Has anyone tried the latest BT software level 1.8.6.6 ? Does it correct this issue ? I have 1.8.5.1 installed, but based on several of the posts here, I am afraid to upgrade..... |
10-02-2013, 06:54 PM | #14 | |
17362
Rep 18,756
10-02-2013, 08:25 PM | #15 |
16
Rep 78
CBS - oil reset
Sorry, 122K miles.
The German auto shop that did the work could not reset it with their BT Pro either. I've contacted BT and asked their opinion. They don't think the software upgrade will help. Just reread your post. I would love to see BMW documentation that CBS stops working at 180,000 miles. That is ridiculous, so absurd. Last edited by cliffschum; 10-02-2013 at 08:41 PM.. Reason: More info |
10-03-2013, 02:33 PM | #16 | |
17362
Rep 18,756
10-03-2013, 02:44 PM | #17 |
16
Rep 78
CBS Oil reset
Yes, I was able to reset via the stalk, now reads 19,000.
fyi, here is reply from BT Tech Service: The BT tool does not yet support the engine oil reset on the MSV70 engine unit. We intend to add that support, but we have not had the necessary information to add it yet. You will likely need to to it manually. There are instructions for doing so on our wiki page: http://wiki.bavariantechnic.com/inde...S#Manual_Reset. Owen Sutton Diagnose Technic 888-854-5523 |
10-03-2013, 09:04 PM | #18 | |
17362
Rep 18,756
12-22-2013, 08:10 AM | #19 |
17362
Rep 18,756
So just to follow up with this thread. After the trip to the dealer, where it was discovered the CBS Oil Service system is designed to stop working after 300,000 kilometers (186,000 miles), BMW has not yet fixed the issue.
I waited 4 months to post this because I wanted to give BMW a chance to fix it and post the whole issue including BMWs resolution of it (just to be fair). Also, I erased my post that originally told about the situation with the software (my post can be found however in post #11) because I didn't want BMW to read it before they had a chance to do something about it. However, since BMW has decided it's not important to them to solve the issue, I've decided to post about it. I posted this yesterday in a separate new thread found here. http://www.e90post.com/forums/showthread.php?t=926864 It may seem like I have an axe to grind because I've posted about it in three separate places, but I want to make sure if someone else has the same problem, they can find it by searching. |
cliffschum15.50 |
05-05-2019, 08:08 PM | #20 |
Rep 30
My 2011 328i is at 185,000 now and I’m kind of expecting this. Is there still confirmation that this is still known to happen even on the LCI cars? I’m thinking of resetting everything this week to hopefully prevent a non reset situation after 186k.
Anyone else past 186,000? |
05-06-2019, 05:24 AM | #21 | |
17362
Rep 18,756
cliffschum15.50 |
05-06-2019, 04:29 PM | #22 |
626
Rep 2,099
So a bit off to the side of topic: Anyone figure out to reset the oil change light and then not have it advance a year? I change mine on a schedule of less than a year, so right now, since the last one in July, I am still at 2020 for my oil change light. I haven't reset it the last time I changed in Mar, but wondering if there was a definitive answer to this? Obviously if I trust the oil for a year in stop-and-go traffic then I'm fine, but otherwise....
