07-18-2013, 09:29 PM | #1 |
[Versatile]
355
Rep 1,683
4 Series M-Performance LSD
As some have already read, the 4 series will have the option of a LSD (Limited-Slip Differential) as an option from the M-Performance Catalog. Do you think they will offer a LSD option for the 3 series?
I also wonder how much it will run considering its mechanical. I'm sure it will be more than the M-Performance Brakes?
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD '13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD '20 AW F87 X3MC - Sold Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build. |
07-18-2013, 10:20 PM | #2 |
704
Rep 886
The 4 series and 3 series should have the same rear end...for the 335i/435i at least...
Now we just need to figure out if the 328i and 335i have the same rear ends! Does anyone know?
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
07-18-2013, 10:51 PM | #3 |
47
Rep 399
For autos they are the same part numbers for 328i and 335i, part number 33107603749.
European delivery 9-19-2012
07-18-2013, 11:19 PM | #4 |
44
Rep 349
07-18-2013, 11:21 PM | #5 | |
704
Rep 886
07-19-2013, 01:04 AM | #6 |
47
Rep 399
Manuals have a different part number but I'm sure they will release for auto as well as manual.
07-19-2013, 04:25 PM | #7 |
704
Rep 886
Hey at least we get a factory differential now! This car needs one SOOOO SOOOO freaking bad
07-19-2013, 05:59 PM | #8 |
649
Rep 4,323
I'm sure we'll get an M Peformance variant soon for the rear diffs...My car needs one desperately, I for one will be eagerly awaiting this!!
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
07-19-2013, 08:53 PM | #9 |
[Versatile]
355
Rep 1,683
I can't wait. Hopefully it doesn't destroy the wallet lol.
07-20-2013, 07:13 AM | #10 |
649
Rep 4,323
it'll probably be $2k installed minimum...
07-20-2013, 10:53 AM | #11 |
162
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
Ha! It'll be more than twice that much. 5k is my guess
07-20-2013, 11:31 AM | #12 |
413
Rep 1,975
I'd guess $5k installed. I'm pretty sure I read that our diff isn't easily accessible... Will need cutting/machining
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
07-20-2013, 02:17 PM | #13 | ||
207
Rep 600
http://www.f30post.com/forums/showthread.php?t=858575 download the "02_F30 Powertrain.pdf" on chapter 7.1, 7.2 and 8.2.1 are some informations about the differential variants. Looks like you said. 328i and 335i (automatic) have the same. 328i (Manual) has the same but with another gear ratio 335i (Manual) has a different one also different gear ratio That's gonna be an expensive after market upgrade Just saw, the part number you listed sells for about $ 1700 plus labour. (And LSD will sure be more expensive than the original diff. I wonder if the software of DSC/DTC also needs to be changed? (With LSD you need to have wheelspin on one wheel to get the other wheel turned.) Last edited by oceanview; 07-20-2013 at 02:23 PM.. |
07-20-2013, 03:58 PM | #14 |
649
Rep 4,323
that's why I was figuring about $2k.
$5k no one would do, so trust me, they wouldn't even offer it.
07-20-2013, 09:38 PM | #16 |
44
Rep 349
I couldn't see it being anything but a factory option. I can't imagine dealerships doing any kind of machining. I just don't think the tooling and/or training is going to be there.
Personally I'm going to sit on the sidelines for an F30 version of http://store.vacmotorsports.com/vac-...als-p2324.aspx . Maybe if enough of us call they'll do the R&D I've had http://www.e90post.com/forums/showthread.php?t=365404 bookmarked for a while. It's missing some pics, but a very good writeup. This guy did his research and concluded Quaife. |
07-21-2013, 02:48 AM | #17 |
155
Rep 1,400
07-21-2013, 07:23 AM | #18 | |
413
Rep 1,975
07-29-2013, 05:13 PM | #19 |
162
Rep 573
I would hope you would order the diff with the right ring gear attached - and turn in your old for a core charge. That's the only way I can imagine that BMW would make it available after market - there's no way the average dealer could machine off the ring gear and tap it for bolts like the wavetrac guys do
08-08-2013, 09:15 AM | #21 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
I will definitely be picking up an LSD as one of my first mods... was looking at Wavetrac or Quaife, but if there's a *reasonably priced* M Perf option, then that would be the way to go. (No warranty issues, etc.)
I wonder how long until they make it available though - I was hoping to get one installed before the end of the year
Ahead of the curve for specF30
08-08-2013, 12:16 PM | #22 | |
649
Rep 4,323
Most owners of the 335i are mildy inelastic up until about $5000. That's why they offered the MPPK WITH a DME (a new DME costs about $3900 according to my dealer) for $899 at cost, or about $1299 MSRP.
