Digital Speedometer Removal
07-18-2013, 06:45 PM | #1 |
335i Owner
56
Rep 839
Drives: BMW 335i 4 Door
Can anyone help me remove this as it's causing a malfunction warning on my car? I'm using Wedge's Coding tool along with NCS Expert. Any help would be much appreciated! If not, I'll just wait for Wedge.
Anyone know where I can find a DIY?
E90 - 2007 BMW 335i Sedan
45K miles 7" VRSF FMIC | BMS DCI | AR Catless DPs | KW v2 Coilovers | M3 Front Control Arms |
07-18-2013, 10:10 PM | #3 |
335i Owner
56
Rep 839
Car with lift, I removed it and it is now gone.
07-19-2013, 05:59 AM | #4 |
37
Rep 252
Update NCS Expert to newer version and Sp-daten, then you can code digital speedo without any issues.
07-19-2013, 11:54 AM | #5 |
335i Owner
56
Rep 839
I have newest version of SP Daten... maybe my NCS expert is too old?
07-19-2013, 12:34 PM | #6 |
164
Rep 401
I've found that if the Daten is too new for the version of NCSexpert you're running that it often will give an error when coding (thus not code at all). I had to revert back to older Datens to make my version of NCSexpert work, so I don't think that is your problem if you have the newest Datens and aren't getting errors in NCS when coding. What version of NCSexpert are you using?
07-19-2013, 12:38 PM | #7 | |
335i Owner
56
Rep 839
07-21-2013, 01:43 AM | #8 |
Rep 38
07-21-2013, 02:36 AM | #9 |
335i Owner
56
Rep 839
I'm not sure, how do I check?
07-21-2013, 10:44 AM | #10 |
Rep 38
The only way to know is by checking the name of the files/folder you downloaded. If it doesn't list what version you are downloading then your probably downloading the wrong one.
My recommendation is for you to use Google.com Than type in: SP-daten-E89_v49 torrent Good luck and report back after you downloaded the torrent listed above. It should be ~3 gig but once you extract the folder it will be ~10 gig. |
07-21-2013, 02:08 PM | #11 | |
37
Rep 252
I will PM you with Lite version, it is totally fine for coding. If you want to program your ECUs you need full, about 10 GB. |
07-21-2013, 04:01 PM | #13 |
335i Owner
56
Rep 839
I downloaded the 4GB one through Wedge on this forum.
