e90 Brake upgrade
07-18-2013, 01:58 AM | #1 |
Rep 3
e90 Brake upgrade
Hi All,
Bit of a noob and had a bit of a search but couldn't really find what I was after. I am considering upgrading my brakes in the near future. It would be mostly for cosmetic reasons to look good through the 19" wheels I will be getting in the next month or so. Probably grooved, drilled discs and calipers. Anyone recommend a good setup to go for that will look good but not brake the bank. (see what I did there?) Any help will be much appreciated. Estimated costs would be good too. The car is a black 07 325d m sport if that helps any. Cheers! |
08-28-2013, 02:29 PM | #3 |
11
Rep 314
I upgraded my front brakes to 335 brakes because the standard 318 brakes looked tiny behind my 19's. All you need is the calipers and carriers, brake discs and brake pads. They bolt straight on. All in including new discs from bmw it ended up costing me about £500
Miggle2.50 |
08-31-2013, 03:19 PM | #4 |
35
Rep 480
If you're only looking for good looking brakes your cheapest option would be to get a set of cross drilled rotors and paint your calipers. A cheap decent set of rotors can be found from Brakemotive, R1, DBA, or EBC (listed cheapest to most expensive). For painting, yes there are really ghetto looking paint jobs, but if done properly look really nice. Check out the blue painted brakes from the related post below.
http://www.e90post.com/forums/showth...ht=show+brakes For the cheapest performance brake upgrade bang for the buck check out this Willwood kit from Revolution Brakes in Oregon. Its an upgrade package to go up to the 348mm disks like the 335i has. You can get them in custom colors for an extra $100. I think this is a better upgrade than the BMW OEM 6pot upgrade because they stiff you and only upgrade you to 330mm discs (tiny). Not worth it. Its actually a downgrade if you have a 335i. The OEM upgrade package is pictured below. They look good, but thats it. You'd get better performance buying a set of used 335i brakes off the forum for about $400-600. Revolution Willwood Brake Upgrade http://www.ebay.com/itm/Big-Brake-Ki...26b80e&vxp=mtr |
08-31-2013, 03:31 PM | #5 |
35
Rep 480
Just for reference, here are the approximate prices for front brake upgrade kits from the different manufacturers. The prices vary a little bit from re-seller to re-seller:
Front Only Stock 335i Used $400-600 (front and rear) Willwood 348mm 4pot $1200 BMW Performance 330 6po $1500 Ksport 300mm 6pot $1500 Ksport 355mm 8pot $2100 Stoptech, Brembo, Rotora, AP, Racing Brake 355mm 6pot $3500+ These places have a good selection for you to see what's available on the market: VividRacing.com GetBMWparts.com CARid.com TurnerMotor Sports ECS Tuning BimmerWorld Side notes: - its possible to bolt on 335i brakes onto other e9x models with no modifications. - it is not possible to bolt M3 brakes onto other e9x models without special adapters. - F30 brakes will not bolt onto any e9x without modifications. - 1 series calipers do no fit e9x without modifications. Last edited by RallyRcrr; 08-31-2013 at 03:37 PM.. |
08-31-2013, 03:53 PM | #6 |
559
Rep 1,502
Drives: F36 435xd
Rallycrr
Just a note about the F30 brakes on E9x's The Performance ones for F30 is sold on german ebay as a bolt-on fit. I have been thinking of doing that on mine....
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
08-31-2013, 05:49 PM | #7 | |
35
Rep 480
Do you have all link? Just searched, and all I could find on ebay was that they only fit F series. http://www.ebay.com/itm/BMW-Big-Brak...22772d&vxp=mtr Description : Brand New High Performance Complete Brake Kit for 2012 F30 BMW 335i Sedan Front: Brembo high-performance 4-piston aluminum fixed caliper on 370x30mm brake discs Rear: Brembo 2-piston aluminum fixed caliper on 345x24mm brake discs Improved thermal resistance larger, internally-ventilated, lightweight-construction sports brake discs. Dimpled and grooved brake discs Dimpled and grooved rotors, internally-ventilated lightweight brake disks with riveted aluminum hat Kit includes: • Front & Rear Yellow Calipers featuring the M logo • Front & Rear Dimpled & Slotted Brake Discs • Front & Rear BMW M Peformance Brake Pads • Front Painted Brake Backing Plates • Front & Rear Brake Wear Sensors This Performance Brake Kit fits the following models : 2012 + F30 BMW 335i Sedan 2012 + F30 BMW 328i Sedan (With the purchase of different rear rotors) Disclaimer : Must use a minimum of 18" wheel |
08-31-2013, 06:30 PM | #8 |
35
Rep 480
anielsen71,
I got this (pic - screen capture) from TurnerMotorSports.com for the F30 OEM BBK and it says it doesn't fit. I'm not doubting you. I want you to be right. I'm just reading otherwise. $2k for a 370mm front & rear kit is really cheap compared to almost $7k from Brembo or Stoptech. http://www.turnermotorsport.com/p-14...335i-2012.aspx |
09-01-2013, 11:04 AM | #9 |
559
Rep 1,502
Drives: F36 435xd
This is what I found:
http://www.ebay.de/itm/BMW-M-Perform...item35cb506a7a It's the same shop as I have seen the other brakes on. I know it does not say anything about F3x models, but as I recall it, it was these brakes said to be for both F3x and E9x. But as you can see, these are actually 370mm in diameter. They should be able to brake... :-)
Brgds
09-01-2013, 12:43 PM | #10 |
559
Rep 1,502
Drives: F36 435xd
@Rallyrcrr
I saw you found Ricky18's thread with the brakes. Same item I found.... :-)
Brgds
09-01-2013, 03:04 PM | #11 |
35
Rep 480
LOL...was telling you the truth when I said I was hoping you were right. Still, I can't find anything on the rear brakes. It looks like it won't fit, but no one has said they've tried either. HP Autowerks hinted that they tried, but didn't say very much about results.
09-02-2013, 01:28 AM | #12 |
559
Rep 1,502
Drives: F36 435xd
Hehehe, yea...you said so :-)
The dealer might have found out that the kit was not completely campatible with both F3x and E9x since the text is changed. But the item is the same as far as I can see. Both by the picture and the specs. and it's the same deealer. The rear brakes might have something to do with the emergency brake as someone said. I don't know if there's a difference there.....
Brgds
