F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Autocross Tires: Widest or Lightest?
Extreme Powerhouse
      07-17-2013, 09:23 PM   #1
nilfinite
22
Drives: F83 M4 & E89 Z4
Getting a set of autocross wheels & tires. 18x8 wheels to stay within SCCA stock guidelines while also getting a square setup.
I've read somewhere in the past that its best to fit the widest tires possible on the wheels for autocross. Is that true? Or is there a balance between tire size and tire weight?
Thanks!
      07-23-2013, 01:40 PM   #2
Forgiven
Forgiven's Avatar
No_Country
122
Drives: 22, X5 45e
I am no expert but that's not true. It's all about stickiness of the tire. Also lighter tires will get more benefits than having light weight wheels.
Wider tires= heavy tires. Especially for autocross, you want ur car to be quick.
G05 - M Performance roof spoiler
      07-23-2013, 08:06 PM   #3
nilfinite
22
Definitely agree about the stickiness. Assuming the same tire, just wondering what would be best.
Based on a bunch of research, I looks the most people say you should get the widest tires you can fit (within reason).
http://farnorthracing.com/autocross_secrets4.html
http://drivefast.org/novice-tips/tire-tips/
      07-23-2013, 08:43 PM   #4
Alpine F31
Alpine F31's Avatar
918
Drives: MB E350 4MATIC Estate
Not sure I agree with this since both the wheels and tires are unsprung weight. You want light wheels AND light tires if you can, but either or will help with handling over the stock boat anchors. Sticky rubber + light wheels = a World of difference in handling. I use Apex wheels (18.1 lbs ea) with Hankook Rs-3 rubber. I only use these for track events and autocrosses and every time I switch out my OE run flats and stock wheels to the "race" set up it feels like I bought a new car! Improved braking, turn-in, grip at the limit and greatly reduced understeer are all positive by-products of a light and sticky wheel/tire set-up.
      07-23-2013, 10:43 PM   #5
Forgiven
Forgiven's Avatar
No_Country
122
Drives: 22, X5 45e
Of course wheel weights are important as tire but since tires are effecting rotational mass more than wheels. The tire weight does matter more than wheel weight... HOWEVER, tire grip matters more than small losses on weight. Losing wheel weight is an essentiall penalty free performance bonus... My main point here is sticky tires->then tire and wheel weights. Do not simply go wider tires and add more weights for no reasons.
      07-23-2013, 10:47 PM   #6
Forgiven
Forgiven's Avatar
No_Country
122
Drives: 22, X5 45e
When I drove my AH3 as stock, I felt I didn't need to go with wider tires at all. Car handles just fine with very min. understeer. I am planning to go with 245/40/18 square.
      08-04-2013, 11:51 PM   #7
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
Arent stickier tires heavier?
      08-05-2013, 12:26 AM   #8
Forgiven
Forgiven's Avatar
No_Country
122
Drives: 22, X5 45e
Yar with bigger sidewall n stuff, also we don't much choice like we do on wheels..:/
      08-06-2013, 09:09 AM   #9
DVC
Diligentia Vis Celeritas
DVC's Avatar
558
Drives: 335i
I was just wondering about something similar to the OP's question... is it worth squeezing in a 9" wheel up front (for a little more tread width) when it's a couple pounds heavier than the 8.5"?
Ahead of the curve for specF30
      08-06-2013, 10:50 AM   #10
nilfinite
22
For my wheels at least (403M), they're 8" up front and 8.5" in the back. So I'd say it's probably worth it.
Plus the 403Ms aren't lightweight wheels. If I wanted to reduce unsprung weight, I'd get rid of the RFTs first and then the wheels second.
f30post
