Cheaper winter setup?
07-16-2013, 06:37 AM | #1 |
Rep 166
Just wondering if I could use bmw style 61 which is a staggered set (8x17 , 8.5x17) and put on bridgestone turanzas 225/45/17 all around. Would the tire size fit on the rears? I dont even know if rotating tires would be possible but it would be easier to find the 225/45/17 tire size on craiglist right?!
Already a thread? Please provide link. Thanks |
07-16-2013, 10:07 AM | #3 |
485
Rep 1,188
Drives: 2008 e92 335xi
You can do this, but running a square tire setup on a staggered wheel setup will look a little strange, but only to someone looking for it.
I run 225/40/18 on 8.5 x 18's in the winter. There is tiny bit of tire stretch, but it totally fine. It also depends on the tire, some run wide/narrower than others. Do you already have the Turnanza's? They are not very good tires for the winter. Also, buying used tires off of Craigslist can be somewhat risky. If you do go that route make sure you inspect all four tires very carefully.
07-16-2013, 01:48 PM | #4 | |
Rep 166
07-16-2013, 02:12 PM | #5 | |
163
Rep 2,823
Why not it's totally fine and hardly any stretch.
Here is some comparison pictures of Remmib old car winter wheels. http://www.e90post.com/forums/showthread.php?t=85623
07-16-2013, 02:19 PM | #6 |
170
Rep 1,843
why not just get square wheels e.g. 157s? That's my winter setup with some Craigslist blizzaks... worked great but damn did the rears wear fast. I'll rotate them this winter and then they'll probably be completely done.
07-16-2013, 08:47 PM | #7 |
A family of bimmers
2748
Rep 7,742
do not run staggered wheels and the same size tire on an xi. the rolling diameter will be off. gotta keep it within 1%
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
07-16-2013, 09:15 PM | #8 | |
60
Rep 910
07-16-2013, 09:49 PM | #9 |
163
Rep 2,823
Wheel size doesn't affect to that. Only tyre size. He is thinking of 8 and 8.5 wheels with 225/45/17 front and rear. Difference is 0%.
07-16-2013, 10:06 PM | #10 | |
297
Rep 393
Drives: 22 G80 Sao Paulo Yellow
07-17-2013, 06:02 AM | #11 |
A family of bimmers
2748
Rep 7,742
nailed it
07-17-2013, 09:46 AM | #13 | |
163
Rep 2,823
Maybe, but i doubt that it would affect that much especially between 8 and 8.5 wide wheels. Maybe if your rear wheel would be 9.5 or wider. 225= 22.5cm wide tyre 8 wheel actual width + 1inch overall width of the wheel= 22.5cm So wheel and tyre have same width. 8.5 wheel actual width + 1inch overall width of the wheel=23.75cm 23.75cm-22.5cm= 1.25cm 1.25cm/2= 0.62cm So 8.5 wheel is 6mm wider/side, than the tyre. http://www.flushstance.com/wheel-measurements/
07-17-2013, 11:14 AM | #14 |
485
Rep 1,188
How much do you think this actually changes the rolling diameter?
07-17-2013, 11:43 AM | #15 |
BimmerPost Supporting Vendor
2044
Rep 25,989
I actually thought about this when I was stretching some tires, and the reality is is that the height of everything is far less affected than you think, especially if it's nothing extreme. OP should not have a problem with 225 tires all around, but with staggered wheels.
VMR|Wheels | 714.442.7916 |
07-18-2013, 12:09 PM | #16 |
Moderator
369
Rep 4,745
+1. The tires are not affected enough to be of any consequence.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
