The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > How to stop angel eyes LED lights from flickering/strobing??? (E93)
      07-11-2013, 03:31 PM   #1
sandere
sandere's Avatar
Drives: BMW X6 E71 -> X5 F15
Angry How to stop angel eyes LED lights from flickering/strobing??? (E93)
Hi All,
Just replaced my angel eyes lights from a bulb to led lights.
After installation i turned them on and they start to permanent flickering
I changed the "PWM_RL_BL_1_FKT_SL" parameter from wert_04 to wert_01 what gave a higher 10.5v output to the leds but the flickering did not stop.
Anyone knwo how to stop the angel eyes LED lights from flickering/strobing?
I already tried to disable the bulb check but it di'd not help.
Gr, Sander.
      07-11-2013, 04:08 PM   #2
E92-Lighting
E92-Lighting's Avatar
860
Drives: Next Generation LED Lighting
our angel eyes are non-flickering
      07-11-2013, 04:38 PM   #3
sandere
sandere's Avatar
When i put normal car battery power on it they are not flickering
so it has to do something with coding some parameters
also after programming the nfrm module they are lighting up at full power and no flickering, after a reset (stop/start button) they start flickering again.
      07-11-2013, 04:52 PM   #4
cn555ic
cn555ic's Avatar
441
Drives: 335i
You have to turn off the warm and cold checks on the Nfrm module. Basically look for warm and Kalt values ending in SL. Make them all nicht_aktiv and the flickering will go away
      07-11-2013, 05:04 PM   #5
sandere
sandere's Avatar
i already did and did not help
WARMUEBERWACHUNG_SL_V
nicht_aktiv
KALTUEBERWACHUNG_SL_V
nicht_aktiv
what about those:
PWM_RL_BL_FKT_SL
wert_01
PWM_SL_V
wert_04
PWM_SL_V_BEI_AKTIVEN_AL
wert_04
PWM_SL_V_BEI_AKTIVEN_FL
wert_04
      07-11-2013, 05:16 PM   #6
BMW..
Guest
n/a
Drives:
nicht_aktiv
nicht_aktiv
what about those:
PWM_RL_BL_FKT_SL
wert_01
PWM_SL_V
wert_04
wert_04
wert_04
Make sure you're programming in manipulate. I always code in expert mode by accident lol
      07-11-2013, 05:19 PM   #7
sandere
sandere's Avatar
the programming is fine i think, i'll do that in expert mode.
i did a verify by doing a "reading" of the nfrm module.
the parameter "PWM_RL_BL_1_FKT_SL" increased the brightness so the coding is just working fine i guess
btw. the flickering is the whole time and is flickering very fast...
      07-11-2013, 05:26 PM   #8
sandere
sandere's Avatar
i think it has to done some with the power output.
changing the "PWM_RL_BL_1_FKT_SL" parameter increased the power to 10.5v (wert_01)
does anyone know how to increase to full power (12v)
      07-12-2013, 02:25 PM   #9
sandere
sandere's Avatar
Did some google search and found the following:
PWM" strings he FRM module don't mean "Power" but actually "Pulse-Width Modulation".
In other words FRM monitors that all the lights are getting 13 Volts at all times.
And how? It turns on and off the power really quick (80hz, 80 times per second) until desired voltage is obtained.
There are no problems with regular incandescent bulbs but that's why some LED's flicker
So i need a way to disable the PWM for the angel eyes.
At another forum i found the following:
Well like angel eyes if we change the voltages in the NETTODAT.TRC it should disable PWM
Does anyone know how to disable (code) the PWM for the angel eyes and if the above is true?
      07-12-2013, 02:28 PM   #10
CasperSYTFU
SYTFU Crew
CasperSYTFU's Avatar
No_Country
36
Drives: 2010 Toyota FJ
The PWM lines affect the desired voltage.
The cold and warm checks control the car actually utilizing the PWM.
Sounds like the LED's you got aren't so good.
      07-14-2013, 01:03 PM   #11
sandere
sandere's Avatar
I found the problem, i checked the power with a Fluke87III meter.
When the engine is off i get a nice clean 12v with a frequency 0HZ
When he engine is on i also get 12v but with a frequency of 80HZ
It's the design of the PWM, it uses the frequency to regulate the voltage.
Thats why the leds are flashing very fast, so the problem is in this case the led's power converter. (not stabalized)
It cannot handle this frequency, is any LED that don't have this problem?
      11-02-2019, 09:08 AM   #12
MrMCoding
Drives: e92
Exclamation
BUMP
      11-02-2019, 09:08 AM   #13
MrMCoding
Drives: e92
did some google search and found the following:
Pwm" strings he frm module don't mean "power" but actually "pulse-width modulation".
In other words frm monitors that all the lights are getting 13 volts at all times.
There are no problems with regular incandescent bulbs but that's why some led's flicker
so i need a way to disable the pwm for the angel eyes.
Well like angel eyes if we change the voltages in the nettodat.trc it should disable pwm
does anyone know how to disable (code) the pwm for the angel eyes and if the above is true?
few years late but i am having this exact same problem.
I have both carly and ncs expert. I have deactivated all cold and warm checks. Angel lights and indicators still flicker when engine on.
E92 frm1. Has pre-lci xenons which i have upgraded to lci xenons. Everything else works fine but the al and side indicators. Please help
      11-02-2019, 03:03 PM   #14
opjose
opjose's Avatar
242
Drives: 335xi
Easy fix, get yourself Automotive In line capacitors.
You can find them on Amazon already wired up with all the connectors to make them plug and go.
The capacitors smooth out the voltage PWM ripples that cause the flickering.
      11-02-2019, 05:47 PM   #15
Sensible_
529
Drives: 2008 E90
Upgrade your FRM. FRM1 isn't designed for LCI LED lights.
      08-08-2020, 11:04 AM   #16
morto
Drives: BMW E90
to stop flickering on angel eyes try this options in FRM2:
PWM_RL_BL_FKT_SL
wert_01
PWM_SL_V
wert_03
wert_03
wert_03
      01-24-2021, 12:29 PM   #17
Cvaggelis95
Sergeant
Cvaggelis95's Avatar
18
Drives: BMW 3 Series E90 LCI
2010 BMW E90  [0.00]
I have the same problem. I own an E90 lci with halo rings and my angel eyes are flickering when I start the ignition. I purchased Carly but can't fix it. Any help guys
Follow for more: https://www.instagram.com/vaggelis.charemis/
ATH, GR | MSc: Banking Administration | UoP
"A hard act to follow, is the best act to follow." | #e90
      01-24-2021, 03:11 PM   #18
TunafishE93
418
Drives: BMW 335i
What are your PWM_RL_BL_FKT_SL,
PWM_SL_V,
PWM_SL_V_BEI_AKTIVEN_AL,
Values?
      01-24-2022, 08:33 AM   #19
kosmokramer
kosmokramer's Avatar
Drives: 2011 328i
Did you get this fixed?
      01-25-2022, 06:15 PM   #20
Cvaggelis95
Sergeant
18
2010 BMW E90  [0.00]
Yes. Changed the bulbs from a professional company and everything is fine now!
