Anyone Try This? Vacuum Bleeder T Mod to Increase Boost!
09-27-2007, 07:40 PM | #1 |
Road Racer
Rep 29
Hello All!
One of the first mods I did on my Supra Turbo when it had the stock turbos was a simple "bleeder" T modification. Basically, insert a Vacuum T in the boost line that goes to the wastegate. This will fool the wastegate into opening up under a higher boost, since some of the air will be "bleeding" out of the T connector. The result is that the car boosts higher...making more power! You can limit the amount of bleed by placing a vacuum cap over the T with a smaller hole. However, from my experience, a wide open T only gave an increase of a couple PSI...so it did not overboost like a pulled hose would. If anyone has done this, where is the best place to put the T into the boost line? I know it must go before the pressure sensor that actuates the wastegates. Does anyone have the diagrams/pages from the service manual that outlines the turbo boost/vacuum system? I would try this now...but picking up my car this weekend so I cant. This is a $.02 modification to increase boost. The stock ECU should correct fuel trims properly. The only problem that could occur is a check engine light due to fuel cut past a certain boost limit....this is what happens on the Supra. But, there was a little black box (signal clamp) to trick the ECU into not cutting boost at 15psi. Looking for a quick adder while I wait for V2 ---------Added---------------------------------- Here is the Supra Tech Article for Reference. You will see the T goes between the VSV and wastegate...therefore it doesn't bleed out MAF metered air and does not affect air/fuel trims. http://www.mkiv.com/techarticles/bleedert/bleedert.htm Thanks! Last edited by MAURYL; 09-27-2007 at 08:17 PM.. Reason: Added Supra Bleeder T Link |
09-27-2007, 07:45 PM | #2 |
788
Rep 7,246
hmm never heard of this, but im sure you'll be getting 10 pages of replies within the next few minutes hah.
LTMW Widebody+1M front bumper+Slek CF Lip|M3 Hood|StopTech BBK|M-Sport Rear Bumper+DD CF Diffuser|Custom Recaro Seats|KW V2|BavX LS3|M3 Side Skirts+Custom CF Lip|BBS CHR 19x10.5+BBS Lugs|LCI Taillights|RD Sport Anti-Sway Bars|GIAC S2|ER Intercooler+CF Shroud+Charge Pipe|Tial BOV|Injen Intake|MS downpipes|Custom Exhaust|BMS Oil Catch Can|M3 DCT wheel+TiD CF Paddles|BMW CF Trunk Spoiler|Aluminum Pedals |
09-27-2007, 08:04 PM | #5 | |
54
Rep 1,677
Not 100% that's true...maybe someone can chime in. But somewhere on here I believe I remember reading not to BOV a car, so I think it would be the same principle. Anyone out there with more experience will be able to tell you for sure..I've heard of the bleeding theory, just figured it wouldn't be the safest/most stable mod out there for this car.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
09-27-2007, 08:08 PM | #6 |
Perf BMW mag issue 147, 159
414
Rep 6,803
not everything you read online is true...
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
09-27-2007, 08:12 PM | #9 |
Road Racer
Rep 29
It definitely is not the most stable...it is a quick fix.
I updated my original post with more input. The BOV to atmosphere lets out A LOT more air. The T on the Supra went between a VSV valve and the wastegate, so therefore it did not affect the MAF air meetering/fuel trims. |
09-27-2007, 08:17 PM | #10 |
Road Racer
Rep 29
You will see the T goes between the VSV and wastegate...therefore it doesn't bleed out MAF metered air and does not affect air/fuel trims. http://www.mkiv.com/techarticles/bleedert/bleedert.htm |
09-27-2007, 08:17 PM | #12 | |
330
Rep 1,134
09-27-2007, 08:21 PM | #14 |
296
Rep 1,515
Drives: Ever changing fleet
LOL! @ all the turbo newbs up in this thread Mauryl, it won't work. That worked on your supra because the turbo wastegates were pressure actuated, not vaccume actuated like the 335's are. The only thing that would happen if you introduced a bleed into the stock wastegate lines would be no boost.
Also, for future reference, a "bleeder" is just another way of saying manual boost controller in conventional wastegate terms....they are in essence the same thing (I said ESSENCE, I don't want to hear about how a Joe P is ball and spring, etc...they still do the same thing). D'oh, beaten by that filthy xedeboy
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
09-27-2007, 08:24 PM | #15 |
Road Racer
Rep 29
AHHHHH....now I'm ghetto! I'm just wondering if this will work, that's all.
Eventually, my Supra had a T72 and was controlled by an AEM....the right way to do it! Peace! |
09-27-2007, 08:27 PM | #16 |
296
Rep 1,515
Nope, won't work on the stock BMW setup at all. If you want more boost, you have to trick the ecu into giving it to you. See the Xede, Juice Box, Procede, etc threads. BTW, a lot of what I was saying above wasn't directed at you, but just to further the lacking common knowledge seen so far
09-27-2007, 08:33 PM | #17 |
Road Racer
Rep 29
The key is vacuum vs. pressure activated. I know there is pressure in the intake...strange that there's no pressure in the boost lines or to a boost pressure sensor??
09-28-2007, 09:58 AM | #19 |
67
Rep 527
Yep, on most other turbo cars the wastegate uses boost pressure to overcome the spring pressure holding the wastegate closed. On the 335's, vacuum actually overcomes the spring pressure in the wastegate.
Bottom line, it won't work.
10 AW on fox E90 M3 with 2 pedals, gentleman’s ride
08 AW on fox E92 M3 also 2 pedals, a bit more rowdy |
