Masconi 120.4 Amp with Gladeen Harness Advice
07-11-2013, 02:22 PM | #1 |
35
Rep 323
Hi Guys,
I have just finished installing a Gladen 200 Series Kit with Masconi 120.4 Amp. On the instructions it says ''For the the correct working of the FSA: If you have a RHD (Right Hand Drive) car, You have to read ''Left'' as ''Right'', so for example, you have to connect your right channel from the source to the ''Left'' channel of the Gladen One amp. In the output, connect your right side speaker to the ''Left'' section. What I want to know if that. If I used a Gladen Harness does this still apply? I have ignored this and moved the settings on my stereo to ''left'' and ''right'' which seems fine to me. Any help would be appreciated.
F82 M4 Competition San Marino
07-11-2013, 03:12 PM | #2 |
118
Rep 2,216
Drives: E91 330d M Sport
Switch them and see - the time alignment is preset for LHD which is why that instruction is there, so if it sounds good now, think how much better it will sound when it's set up properly
Just how many Yorkshire sheep can you fit inside one exhaust?
07-15-2013, 01:52 AM | #3 | |
40
Rep 386
How does your set up sound now? |
07-15-2013, 05:20 AM | #4 | |
35
Rep 323
I found these on the bottom border of my instruction manual. Mine is a non dsp version so could be different to yours. Cheers, Kal
07-15-2013, 12:01 PM | #5 |
40
Rep 386
I don't have a DSP version either. I have a slightly cheaper amp than to 120.4 amp you have too. I've checked the instructions and can't find anything regarding this.
How does yours sound now that Sam has played with the settings? |
07-15-2013, 02:12 PM | #6 | |
35
Rep 323
I've had the Alpine upgrade on my previous E92 335D and had BMW loudspeaker system on my E92 320D... This system is far better than both of them defiantly a noticeable difference. Hope that helps... p.s. I used a 2 channel harness an use the head unit to power the rears. Cheers, Kal
07-15-2013, 02:49 PM | #7 | |
889
Rep 9,097
I have listened to few Gladen kits in different cars. IMHO, your kits sounds the best out all Gladen kits I have heard. As Gladen kits are same, so I guess difference is Mosconi amp and the codings to adjust pdc / gongs and all worked well. I am sure that this kind of sound system will keep you smiling for few months now.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
07-15-2013, 04:06 PM | #8 |
12
Rep 81
Hi Kal,
glad its all sorted, and you are happy with the sound, i knew the kit would sound good, as its got all the top spec stuff shame i never got any use out of it, apart from it taking space in my cupboard. |
07-16-2013, 04:23 AM | #9 |
35
Rep 323
Much Appreciated!
