07-11-2013, 09:33 AM | #1 |
102
Rep 1,903
Drives: e92 335i 6MT
Active Cruise Control Folks - Please Chime In
Hi guys, So I've got ACC on my recently acquired E92 335i. Its so rare on the E9X I figured I'd get more hits here...
Its a neat feature, however, recently I've been getting the 'Active Cruise Control malfunction'. Connecting to INPA, the error message is 'sensor out of adjustment' Apparently, the ACC system is very sensitive, and can throw an error even if its off by a few degrees. I did switch to a set of aftermarket wheels with larger than stock tires and I'm thinking that may be the culprit. So my question to other ACC users is, did you encounter the same problem when switching to aftermarket or winter rims? Or perhaps when lowered on coilovers? Was your dealer willing to realign it under warranty? I'm out of warranty and my local dealer wants to charge $500 to have it readjusted I hear its quite the show that includes jigs, lasers and an alignment wall. ACC is something I rarely use, but I cannot even use regular cruise control if it malfunctions. Definitely something to consider for those on the fence about getting this option.... |
07-11-2013, 10:46 AM | #2 |
Dinosaur supervisor
3030
Rep 4,214
I had the ACC on my E92 too, and I got that after I installed a new front lip (OEM addon) and accidentally pushed the "eye" a few millimeters. I ran 5 different wheels and coilovers on my car without issues so that would not change anything.
I would look into if something has pushed the "eye" out of its original placements. Maybe you have hit something (small bird). And on the F30 they use a completely different sensor that cant be moved in the same way so no problems like that. And the only issue I ever had with my ACC was when I screwed up, other than that it worked like a charm for years. |
07-11-2013, 11:17 AM | #3 | |
102
Rep 1,903
07-11-2013, 02:07 PM | #4 | |
Dinosaur supervisor
3030
Rep 4,214
But I didn't get a fault code (that I know of). My actual error showed up on the nav screen (exact same message as your fault code though). |
07-11-2013, 04:13 PM | #5 |
26
Rep 159
Drives: '13 335i Sport Melb. Red
Almost 18,000 miles and no permanent ACC faults here. If I am in really bad rain, my car will give me an ACC fault, different from the fault it gives you if it hydroplanes slightly, but an ignition cycle always clears it.
Now passenger airbag fault warning... I see that on a weekly basis.
2013 335i F30 Melb Red Dakota Black/Red highlight
Sport Line, Driver Assistance, Driver Assistance Plus, Dynamic Handling, Premium Pkg, Tech Pkg, Sport Auto Trans, Active Cruise Control, Heated Front Seats, Auto High Beams, Parking Assistant, Harmon Kardon |
Tags |
acc, active cruise control |
