DME Rom version?
07-10-2013, 06:00 PM | #1 |
86
Rep 1,262
DME Rom version?
Hello guys. Is it possible to check the DME Rom version with INPA? If so how ?
Tried searching this but couldn't find anything good... Thanks!
Josh-
07-10-2013, 08:26 PM | #2 |
Guest
Rep n/a
Drives:
07-10-2013, 09:24 PM | #4 |
38
Rep 1,079
Thanks! I've been looking for this for a while too.
2004 E46 M3 | Imola Red on Cinnamon | Slicktop | Manual Seats | 6spd MT |
07-10-2013, 09:51 PM | #6 |
Guest
Rep n/a
Drives:
Not sure about this but check in winkfp the higher the zb the newer it is? Idk dont quote me when you pick update ecu then enter vin then do prog-zb-update it will show which is the latest to update too
07-12-2013, 08:19 AM | #7 |
37
Rep 252
Better way to do it is to check what ISTA-P says. I mean that it is better if you will not suggest to Winkfp latest update for your ECU because it won't let you keep proper Integration Level (50/50 chance that will select proper). Check what ISTA-P wants to update and which version wants to use and then go back to Winkfp and select this one from ISTA. Obvious that ISTA-P doesn't let you flash individual ECU, but winkfp does.
