Adaptive headlights
07-08-2013, 08:08 PM | #1 |
Yiannis Gazis
97
Rep 734
Drives: 2007 328xi
Adaptive headlights
Is it normal for adaptive xenons to self level at start up to go up and down then side to side or just up and down? Trying to figure out which headlight is giving me the adaptive headlight error...
2nd Bimmer - 2013 335is | Alpine White | DCT | Loaded
1st Bimmer - 2007 328xi | SGM | e90 | Premium | Navi | Gloss black trim | Cold | AA headers | 3 stage intake manifold | AA stage 3 tune | AFE stage 2 intake | Cyba Scoops | OEM Blacklines | OEM LCI mtech front bumper | OEM LCI hood | OEM gloss black kidney grills | Orion v4 LED halos with blackout headlights | Valentine 1 Radar | Sport wheel with paddles | kw v1 coilovers | VMR 710 | Continental ExtremeContact DW | |
07-08-2013, 08:49 PM | #2 |
19
Rep 243
Hmmm I know mine go up and down, but not sure about side to side, I think they pan a little but not full side to side. But I assume they're fine otherwise you'll get a warning.
2008 BMW 335i M-Sport Black Saph w/ Dakato Black | M-Sport | Sunroof | iDrive | 6SP Steptronic | Comfort Access | Lights Package | JDM Spec |
07-08-2013, 08:55 PM | #3 |
Yiannis Gazis
97
Rep 734
Drives: 2007 328xi
I have an adaptive headlight malfunction warning and the auto headlight led light is blinking...passenger headlight at start up goes up/down and left/right...however the drivers only goes up/down...I also have euro headlights...wondering which side is normal?
07-08-2013, 11:50 PM | #4 |
Where'd my VTEC go?
481
Rep 6,067
Both of mine only go up and down.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
07-09-2013, 12:05 AM | #5 |
681
Rep 3,696
Lots of info to share here:
1) bi xenons at start up should do a self leveling down/up test 2) bi xenons have the ability to tilt left/right ONLY when the light switch is in automatic mode. 2a) when the vehicle is stationary or moving AND light switch is in automatic mode, then only the passenger side bi xenon light will move right/center. 2b) when the vehicle is moving greater than 25 mph AND light switch is in automatic mode, then only will the drivers side tilt left/center. Learned this in the bentley manual and on several postings here. To figure out what your car is complaining about, use the BC Stalk to go to the check control. Cycle to the error u want details about, then press and hold the BC Stalk button until you see a CC ID number appear below the error icon. Google search "e9x cc id xxx" (u fill in the x's) |
07-09-2013, 05:41 AM | #6 |
Yiannis Gazis
97
Rep 734
Drives: 2007 328xi
Thanks will do the bc stalk to check cc id
07-09-2013, 06:33 AM | #8 |
681
Rep 3,696
Try switching your headlight switch to full left (Automatic mode). While parked, crank your steering wheel full right. See how you passenger side light tilts to the right along with the steering wheel movement (step 2a in my instructions).
