07-08-2013, 01:53 AM | #1 |
Rep 2
F30 Boot Opening issue - SOLUTION
Hi all,
Problem: Boot does not open up fully when you use the remote boot lid button or from inside the car. Had this intermittent problem since i bought the car, and been searching all over google for posts on how to fix it. The dealership was not helpful at all, brought my car back several times to look at this and they didn't think the spring was adjustable. Thanks to this post http://www.f30post.com/forums/showthread.php?t=857273 there is a way to resolve the problem. Here are some pics I took for those who want to fix. Left side of the boot lining: 1. Only removed one clip on the left side of the boot lining (the area behind the brake lights) 2. You can use your hand/slide a plastic ruler to pull out the lining. I lifted the rubber seal a little with my fingernail to reveal the end of the lining so i could pull it out. 3. Here you can see the spring to adjust. I stuck my hand in and just pulled it to the slot further from hinge. Right Side: Same steps as the left side but no clips to remove. Mine has a removable storage piece that allows access to the battery, which i took out to make it easier to pull the lining out under the seal. Hope this helps anyone who has a similar issue! Last edited by ucheokeke; 07-08-2013 at 02:05 AM.. Reason: Broken image links |
11-04-2014, 07:34 AM | #3 |
35
Rep 214
Thanks for the photos. Fixed mine too!
Current: 2019 G05 x5 50i M-Sport
Past: 2016 F10 550i M-Sport ~ 2015 F83 M4 Convertible ~ 2013 F30 335i M-Sport ~ 2006 E85 Z4 30i |
12-17-2014, 07:50 AM | #5 | |
Member
Rep 17
12-17-2014, 07:51 AM | #6 | |
Member
Rep 17
09-16-2016, 02:55 PM | #8 |
5697
Rep 3,225
You don't really need the pics mate. Just open up the top of the boot where the springs are and you'll see, it's very easy.
09-22-2016, 01:35 PM | #9 | |
Rep 35
2 wasn't quite enough for me so had to go with 3. |
05-18-2018, 06:51 PM | #11 | |
Rep 2
05-18-2018, 10:07 PM | #12 |
23
Rep 163
You have a different model (e93). The trunk hinge mechanism is different between your car and the ones mentioned in this thread. Try the E90 forums for threads more relevant to your model.
05-20-2018, 10:28 PM | #13 |
Rep 2
06-17-2020, 11:07 AM | #14 |
18
Rep 67
Ressurecting this thread from the dead, just for visibility as our cars start to show their age. Noticed my 2014 335i trunk wasn't opening all the way automatically, and the method above worked.
02-03-2022, 02:03 PM | #15 |
Rep 63
Resurrecting again , I'm having this issue. Does anyone have instructions to the solution? I'm unable to open the linked thread
02-04-2022, 05:40 AM | #16 |
5697
Rep 3,225
Tags |
boot not opening, boot open issue, f30 boot problems |
