BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > HOW TO: Remove Front grills on F20
      07-03-2013, 06:52 AM   #1
SN1P3R
SN1P3R's Avatar
South Africa
11
Drives: F20 118i sport
Lightbulb HOW TO: Remove Front grills on F20
Hi all...
So after 8 long hours of research looking for a way to remove the grill on my F20 so I could have it painted, I turned up with nothing but a how-to on getting to the top clips.
So I decided last week to spend 4 hours exploring different methods to get them off, and then share it with you guys and other forums to help enlighten other F20 owners who would have spent R1800/or whatever your countries equivalent is for getting BMW to do it for them.
Step 1: Remove Rubber lining from the top of the Bumper.
Step 2: Remove the 6 bolts that you find under the rubber.
Step 3: Pull a section of the bumper above one grill using a light you should see the first 3 clips, use a long thin flat head screwdriver to depress the clips forward.
ONCE THIS STEP HAS BEEN DONE YOU CAN GO AHEAD AND PUT THE BOLTS AND THE RUBBER BACK ON THE BUMPER.
Step 4: Once the top 3 clips are out there are 2 clips, one on either side of the grill in the center, these you can depress with your fingers if you get your hand between the gaps and curl them you should be able to feel them.
Step 5: Now comes the tricky part, once the all the other clips are out you are going to struggle to get the last 3 out so what i recommend is using a small light placed behind the grill shining towards you and a small mirror or a facetime camera on a phone so that you can see the clips from inside the bumper. Once you can see what you're doing you can make a tool using a spoon or a strong, thin piece of metal, bend it into a hook-like tool and shape the end to match the shape of the clip. then using the mirror and the light you can unclip the last part of the grill. (check the bottom of the post for an example)
I WOULD RECOMMEND ONLY DOING ONE SIDE FIRST AS THE PROCESS OF REMOVING THE SECOND ONE WILL BE EASIER.
Now if you have bought replacement grills you can simply clip them in, if not and you wish to further separate the chrome from the grill follow the last step:
Step 6:There are 8 clips in total that hold the grill together.
Now that the grills are apart you can DIY paint them, send them to be wrapped or have them hydrograph dipped.
I personally sprayed mine matte black.
One final note to put the grill back together just reverse step 6.
Hope this will be helpful to you guys who want to do this
Here are the pics of the tool I made for this job (Thanks to @Bradbury for the tip to make this tool)
      07-30-2013, 09:32 AM   #2
iBeech
iBeech's Avatar
England
109
Drives: BMW 520D F11 2015
Thank you for sharing!!
      07-31-2013, 06:40 AM   #3
Maxib37
12
Drives: Bmw f20 sport
Finally someone who knows what there doing lol
      08-19-2013, 02:45 PM   #4
EdenH
Drives: F21 116i M Sport
Thanks for the guide! Sprayed mine up black too, turned out great
Before
After
      09-11-2013, 07:05 AM   #5
Bruce GT3
Drives: M135i
Just removed my grilles prior to inserting some MP ones - thanks for the guide, it was invaluable!!
      02-16-2014, 07:17 AM   #6
as7920
as7920's Avatar
596
Drives: 2023 SG/FR M4 xDrive Competiti
Just fitted my m performance today with the help of this thread.
Getting/making the right tool for the job was the difference between success and failure and I was about to give up until I found this.
A modified tent peg was he answer in a shape similar to your spoon!
      02-19-2014, 02:28 PM   #7
stege123
stege123's Avatar
Drives: e46
Thanks for the useful info
      03-01-2014, 01:26 AM   #8
BWT
Drives: M3
Hi all
Can the tool be used to pick the top and bottom clips (ie skip steps 1-3 of SN1P3R's post)?
Thanks
      03-02-2014, 05:46 PM   #9
as7920
as7920's Avatar
596
Originally Posted by BWT View Post
Hi all
Thanks
I thought about that afterwards and I'd guess it's entirely possible though it will be harder to get the first three initially.
Give it a go that way first.
      03-14-2014, 10:57 AM   #10
Guynamedsean
31
Drives: 2012 Carbon Black 650i M Sport
I am going try this on a m235i.
I've heard people say you can just rip the old ones out, but you will damage the clips.
I plan to throw out the original grills and replace m performance grills.
will the damage be to the original grill only or the car? I don't really care if I damage the original grill.
      04-08-2014, 11:16 AM   #11
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
As per my PM to you.If you don't intend keeping the old ones. Just cut the upright bars of one side then you can get behind both grills
Current car.M240i.
Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci.
      04-15-2014, 04:55 AM   #12
///Chase
///Chase's Avatar
Australia
114
Drives: 16' m4
I did this yesterday, following the guide. I actually got all of the clips out from behind with just my hands (without breaking any clips), no tools required. Its not hard just requires a bit of determination.
      04-24-2014, 11:05 AM   #13
Freaknice
Drives: BMW 116dMsport GS
What colour are the grills before hand?
      04-24-2014, 03:15 PM   #14
Mad Mental Jock
Scotland
Drives: Estoril Blue F21 120d MSport+
Just did mine following this guide, so thanks for the help. If I had to do another, I think the the modified tea spoon could be used for the top clips avoiding the removal of the bumper bolts.
The early bird may get the worm !
But the second mouse gets the cheese !
      08-21-2014, 10:18 AM   #15
lee335
15
Drives: BMW 335i M-sport Coupe
For the people who sprayed the grill what did you use please? And also how does it do against chips?
Great guid!
      10-16-2014, 07:11 AM   #16
GeoBem007
Belgium
28
Drives: F21 M135i
I did mine yesterday the same way.
Put my hand/arm through the gap and got the clips out without tools.
My arm was not too happy about it, but it worked (and took me about 15min).
      10-21-2014, 05:38 AM   #17
Bee Pee
1738
Drives: AW M2 DCT
One of my grilles was removed using a riding boot pull, thanks to Karen on Babybmw for her help. No need to even lift the bonnet. 5-10mins and grill popped out. Top 3 1st working from each side before doing the centre clip, then the vertical clips [one per side]. Finally, repeat the same sequence on the bottom 3 clips. Helps to have an extra hand to [gently] pull on the grille whilst manipulating the boot pull between grille slats.
Definitely helps having a extra grill to view as reference to check where the position of the clips are.
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT
      02-15-2017, 02:18 PM   #18
Martin Kik
Drives: BMW F20
Excellent write up ! Did mine today, it's awesome !
      04-13-2023, 10:00 AM   #19
cururu
Drives: BMW 120i F20
Great help. thank you!
Search this Thread:
Advanced Search
1addicts
