Spec 2+
06-29-2013, 07:06 PM | #1 |
27
Rep 388
Spec 2+
Anyone with the Steel SMFW and Spec 2+ setup know if the stutter getting into first and or reverse dies down after the 500/600 mile break-in period? I guess the same question goes for the chatter although I can certainly live with it if this is the worst it gets.
335 XI Coupe/ RB Turbos/ JB4 w/ Wedge Backend / Meth / Inline LPFP / E85 / UUC SSK / Spec2+ SMFW / HPF 7'' IC / Forged DV's / AR DP's / BMS DCI / Apex Arc-8 /Hankook Ventus V12 EVO / KWV1 / HPF Exhaust/ NGK/
06-29-2013, 07:17 PM | #2 | |
21
Rep 414
Chatter also doesn't get better. Turn off the ac to get less chatter.
2017 F82
06-29-2013, 07:28 PM | #3 |
27
Rep 388
Figured - and figured. Thanks man. The modified CDV that you have worth looking into? How about the DV's?
06-29-2013, 11:02 PM | #4 | |
21
Rep 414
Modified CDC is worth it for 2nd gear engagement. You need upgraded DVs if you are running 15+ pds boost
2017 F82
06-29-2013, 11:55 PM | #6 | |
200
Rep 2,799
thanks to MGallop |
06-30-2013, 10:36 AM | #7 |
59
Rep 886
Does the upgraded clutch really better than oem? And did you upgraded because your started to slip or just to upgrade?
Bmw 335xi/FBO/ black on black/ 6sp manual/Cobb AP/BMS DCI/AA BOV KIT/VRSF DP'S/VRSF 7'FMIC /FULLY CATLESS/H&R sport springs/ 19' ac schnitzer wheels.
06-30-2013, 11:28 AM | #8 |
555
Rep 739
I have the Spec stage 2+ w/ steel SMFW for about 2000 miles. The engagement does get smoother over time. I don't even notice it anymore, but in general it want's to be engaged quicker than stock so slipping it really slow from a stop may always give some amount of stutter. If you commit to taking off and give it enough gas though it feels great. I upgraded at 60K miles because stock clutch was slipping with FBO, E85 and meth. The chatter will always be there, nothing you can do about that. Overall I've been very happy with the clutch and flywheel. It's solid.
06-30-2013, 11:34 AM | #9 | |
59
Rep 886
Thank you very much for the info, i will try e85 maps next 2 weeks so i'll see if i need an upgrade.
06-30-2013, 01:48 PM | #10 |
21
Rep 414
Does the upgraded clutch really better than oem? And did you upgraded because your started to slip or just to upgrade?[/QUOTE]
My clutch started to slip when I was running 100% E85+meth.
2017 F82
06-30-2013, 03:19 PM | #11 |
104
Rep 1,529
damn i wish there was someone around where i live that has the steel flywheel...im on the fence about getting it as i dont want it to chatter so much where i cant live with it.
anyone in the 757, 804 or 703 wanna give me a ride?
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
06-30-2013, 07:52 PM | #12 | |
59
Rep 886
how much power your car produces on such a setup? 1/4 time?
06-30-2013, 08:02 PM | #13 | |
52
Rep 748
Although, I am moving to Atlanta in 2 weeks.
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
06-30-2013, 08:08 PM | #14 | ||
New kid on the block
Rep 131
Drives: 09 335i coupe
06-30-2013, 08:28 PM | #15 |
52
Rep 748
Sure thing. Planning on moving in July 15... so I should be free a couple days after that when I get settled.
06-30-2013, 09:11 PM | #16 |
104
Rep 1,529
hell yeah man...ill send you pm with my number...im actually up in richmond quite often now.
06-30-2013, 09:37 PM | #17 | |
Rep 182
I may be reaching out to you in the near future if your offer to see the car carries through a couple states to Atlanta.. |
06-30-2013, 09:46 PM | #18 | |
52
Rep 748
Mine doesn't usually gear chatter (or rattle) when cold and I usually don't notice it at all unless I have my AC on (which I don't hear with my windows up). On the flip side there are times when I start the car and do hear it... As for clutch chatter during engagement, it only really happens with slow engagement in 1st/reverse. Even when it does, it's not loud at all. Lastly, the clutch definitely got better after the first 1000 miles.
06-30-2013, 11:49 PM | #19 | |
21
Rep 414
Hitting 20psi pre-5k, car is fast and responsive.
2017 F82
07-01-2013, 05:38 AM | #20 |
59
Rep 886
May be you've raced some fast cars? Just to compare the level of power your car is producing.
07-01-2013, 10:12 AM | #21 | |
3441
Rep 79,211
I personally cleaned up a lot of excessive wastegate duty cycles when i switched to the Tial BOV. I was running about 19 PSI peak tapering to about 15 by redline. |
07-01-2013, 10:25 AM | #22 | |
17
Rep 575
