06-27-2013, 12:24 PM | #1 |
Rep 8
HELP akra exhaust noise
exhaust noise! i got my full akra intalled few months ago. but sometime when i just start the engine(cold) theres a metal noise form my akra exhaust. is like 2 aluminium papier hittin each other. Only happen when is cold-start. And i when to garage the enginer checked allrdy. They didint find anything! So im wonderin if anyone have the same problem.
Thx |
06-27-2013, 02:32 PM | #2 |
83
Rep 1,489
Is it a high-pitched rattle coming from the muffler?
To see if this is it, fire up the car, go to the side making the noise, and push the valve open and then let it close. Push the valve all the way closed. If it goes away when open and then when pushed closed you found the issue. That is what mine was doing. I tried to extend the ball and socket to close it further but it was almost all the way out already - so I just bent the actuator bracket a bit to close off the valve all the way, voila - no more rattle.
Current: '16 GT4
Past ///Ms: '13 F10 M5, Alpine Weiss III/Sakhir Orange Full '10 E60 M5, Space Gray/Black |
06-27-2013, 09:52 PM | #3 | |
Rep 8
06-27-2013, 10:04 PM | #4 |
125
Rep 1,583
Where do you hear the noise? In back or more toward the driver?
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread: http://www.6post.com/forums/showthread.php?t=794659 |
06-28-2013, 06:54 AM | #5 |
///M Fan
1650
Rep 1,490
Noise
Interesting my Akra on M6 does not make any such noise. I wonder if it was an install problem? There are multiple brackets that have to be removed and properly reinstalled. I would make your mechanic check each one of these as well. There could be one not properly torqued down and it only vibrates at certain frequencies.
Noushy
2019 BMW X5 50i Mineral White/Tartufo all options including M Sport
2022 Porsche 911 C4S Silver/Brown 2023 BMW iX M60 Black Sapphire/Amido, Titanium Bronze trim/22 2023 Audi RS6 Avant Daytona Gray/Black 2024 BMW X5M Comp Brooklyn Gray/Taruma Brown, Titanium Exhaust on order |
06-28-2013, 10:15 AM | #6 | |
83
Rep 1,489
Current: '16 GT4
06-30-2013, 05:48 PM | #7 |
Knight Commander
554
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
Your exhaust valve needs to be adjusted. It's too loose correctly.
Eisenmann/IND has instructions on how to fix this on Eisenmann exhausts. Its a simple adjustment.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
07-02-2013, 08:08 PM | #9 | |
Rep 8
Thx |
07-02-2013, 08:24 PM | #10 | ||
Knight Commander
554
Rep 5,948
