06-24-2013, 09:02 PM | #1 |
57
Rep 603
Which modes is eLSD on?
I am not talking about traction off going into comfort mode, stiffening of suspension or stiffening of throttle and steering, i am asking about the eLSD.
eLSD is definitely on with Sports+ mode. Is eLSD on with all aids off? does the shifter have to be in DS/MS mode to activate eLSD? Is there any official posts from BMW about which settings puts eLSD on? Is there a way to test eLSD? |
06-25-2013, 08:32 AM | #2 |
21
Rep 101
To my knowledge the 3 series doesn't have a eLSD. The ///M cars (M5 & M6) do and the M3 has a regular LSD.
The way to test if you have a LSD is to burn rubber, if you have one tire mark it's a open diff. If you have two tire marks, then you have a LSD. The other way to tell is to lift the rear of the car and spin one wheel, if the other wheel goes in the same direction then you have a LSD, if it spins in the opposite direction it's a open diff. An eLSD has an electronic module hanging off the side of the diff. case, it works like a open diff. when not activated. Last edited by robbieracer; 06-25-2013 at 08:43 AM.. |
xxxjecxxx2153.00 |
06-25-2013, 08:42 AM | #3 |
38
Rep 387
Mechanically, it's an open diff. The only mode that engages the Automatic Differential Brake ADB system is DSC OFF. (That's the hold-button-down-for-several-seconds mode.)
Source: http://prodcds.bmwuniversity.com/lib...20Dynamics.pdf |
06-25-2013, 08:52 AM | #4 |
50
Rep 1,730
Cool document, should also serve as a good reference for people who ask about DHP and the electronic dampers. Lots of acronyms
Edit - also interesting to understand how VSS is implemented. For some reason I thought it involved motors (not sure how that makes sense) but in fact the gearing ratio on the rack just changes off center. Last edited by drob23; 06-25-2013 at 09:06 AM.. |
06-25-2013, 10:18 AM | #5 | |
14
Rep 162
Previous: E92 328i 6MT
Future: AW F30 335i | ZSL | ZMT| Heated Seats Ordered: 6/15/13 - Production: 6/20/13 - 6/26/13 - Boarded Euphony Ace 7/6/13 |
