06-21-2013, 02:26 PM | #1 |
1048
Rep 5,660
Has Anyone Ignored the Premium Fuel Mandate?
I bought my kid a 328 F30. He called me this a.m. asking if he really had to put premium gas in it. I told him if he wanted to save some money, he could fill up with premium one time and then going forward, upon the needle showing half full, top it off again with mid-grade octane fuel. I said further that that so long as he keep refueling at the half full point, he could alternate back and forth and be okay, but that if he falls below half, he should only refill with premium.
He doesn't want to do that. (This shouldn't surprise you or me; kids always just want to do it their way, even when they ask and you tell them something other than what they had in mind.) He just wants to use mid-grade all the time. So, if anyone here has tried using mid-grade all the time, have you observed any ill affects from having done so? I've read a variety of stuff on the Internet about this matter, (http://usatoday30.usatoday.com/money...emiumgas_x.htm among others), but I'm interested in what real owners here are experiencing (not what they think, surmise or believe) from having done so.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
06-21-2013, 02:33 PM | #2 |
38
Rep 596
I wouldn't recommend it - it may be cheaper in the short term, but can cost you a lot more in the long run. Using lower grade gasoline can cause engine knocking and your mileage will probably degrade.
2013 BMW 335i xDrive Sport Line
06-21-2013, 02:37 PM | #3 |
34
Rep 568
Ultimately using the high grade fuel will be cheaper, since you'll both get a) more mileage from it and b)save undue wear and tear on your engine. If your kid wants to save some money, tell him to try running it on eco-pro in the city/burbs, and only shifting to sport when he has some open road. I used to average 23 mpg on comfort/sport when I first got my 328, but once I got the "new car rush" out of my system and started driving eco-pro more in heavy traffic/stoplight areas, i've bumped it up to close to 30 mpg.
06-21-2013, 02:49 PM | #4 |
50
Rep 1,730
I don't agree with the above, the engine knock sensors will inform the ECU to adjust timing accordingly, you won't do damage to a modern engine like the N20 with regular octane gas. You will sacrifice some performance in the high RPM band, and the engine will run slightly more inefficiently. I was told this a while back by some researchers working on HCCI stuff at a University.
The only caution I'd add is to run the same type of gas. The ECU will adjust these parameters over a windowed period (maybe a tank or two), so changing the octane level up and down with an eyeball cocktail is not the way to go. Just tell him to stick with 89. You ask for solid advice, but I think unless you speak to an engineer who works on combustion systems or maybe a mechanic who's active these days, everyone is just going to give you whatever black magic theories they have. How can one reasonably discern whether the octane level is truly affecting anything? Only thing I can think of is people drag racing their cars or mayyybe claiming fuel economy differences. |
06-21-2013, 03:03 PM | #6 |
1538
Rep 3,331
Your first problem was not letting him drive a 92 Civic until he gets a job. LOL.
Realistically he isn't going to damage anything by running cheap gas, the car is designed to adapt to it. With that said, he'll likely get worse fuel economy and certainly lower performance, especially when pushing the engine. If he's just lugging around town there won't be a significant difference. Simple answer: Tell him if he wants cheaper gas you'll trade his car in for a Hyundai that takes 87....that should straighten him out right quick.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
06-21-2013, 03:24 PM | #7 |
6659
Rep 15,858
06-21-2013, 03:38 PM | #8 |
51
Rep 1,831
Drives: 335i MSport + MPS/MPPK
We are talking about a difference of $1.60-$2.00 per fill up. He can save that by cutting out one coffee at his local coffee shop!
06-21-2013, 04:58 PM | #9 |
24
Rep 345
Manual says 89 AKI - that's mid-grade so your car will be fine.
Here in Canada most mid-grades include ethanol, up to 10% - which can result in a 3-5% decrease in mileage. So filling up with premium (no ethanol) for 3-5% more is a wash.
2017 M240i xDrive Loaded 2013 328 xDrive Premium, Executive 2007 335i Premium |
06-21-2013, 06:22 PM | #10 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Again...saving $2 per tank just isn't worth the grief it might cause you if your engine develops problems and BMW finds out you've not been using the recommended fuel as it CLEARLY states on the gas filler.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
06-21-2013, 06:53 PM | #13 |
Rep 64
06-21-2013, 07:41 PM | #14 |
2067
Rep 5,373
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
06-21-2013, 07:57 PM | #15 | |||||
1048
Rep 5,660
My boy asked me a question for which I don't have much personal experience upon which I can rely to give him a very good answer, and I'm looking to collect some data and give him a better answer than I already did about what other folks have actually experienced by having done what it is he asked about. Quote:
But overall, you are right. It's very hard to get facts, even when that's all that's requested. Opinions are easy to come by, but as I have plenty of my own, I don't generally seek other folks' opinions. It's nice that folks share their opinions, and I appreciate the sentiment that accompanies their having done so, but that's not really helping me draw a conclusion for myself. I can say that I one time filled my my E92's fuel tank with regular (87 octane) and drove it with no ill affects observed. I was in a small town -- more a village than a town, really -- that had one gas station and the other octanes were sold out. I wasn't going to drive over 120 miles to fill up on high test when I needed to be in that town for the whole week; it was just the decision I made. But that was one time. I was hoping to collect some additional data points.
Cheers,
06-21-2013, 08:00 PM | #16 | |
1048
Rep 5,660
We'll see if that actually happens. So far it hasn't.
Cheers,
06-21-2013, 08:03 PM | #17 | |
38
Rep 596
http://www.bmwusa.com/Standard/Conte...fications.aspx Premium gas means 91/93 octane.
06-21-2013, 08:07 PM | #18 | |
1048
Rep 5,660
Cheers,
06-21-2013, 08:13 PM | #19 |
38
Rep 596
Well, let us know how it goes.
06-21-2013, 08:19 PM | #20 |
1048
Rep 5,660
TY all who replied. Perhaps I need to clarify.
My son and I have both read the owner's manual. It says" BMW "recommends" 91 octane as the standard fuel and 89 octane as the minimum octane fuel. It also says that using fuel rated below 89 octane may impair performance. So what I want to know if if anyone has OBSERVED a performance reduction and if so, under what circumstances? - What octane fuel did you use? - How long did you use it? - What performance reduction did you OBSERVE? - If it's relevant, what type of driving were you doing when you OBSERVED the performance reduction? (e.g., city driving where you floor the gas from stop light to stop light; highway cruising at some speed; driving like 90% of the population does around the 'burbs, hauling ass around remote, twisty rural roads as though you were on a race track; on a track, etc.)
Cheers,
06-21-2013, 08:29 PM | #21 |
175
Rep 646
I don't think you are going to get that answer from anyone on this forum. People on the forum are enthusiasts and are not about to take a chance on running low grade fuel in automobiles that they paid a lot of money for and appreciate. The car is turbocharged, has direct injection, runs a high compression ratio, etc - therefore high grade fuel is a must - thats why it is recommended.
Tell your son to run premium as stated by the manufacturer who made the car in the first place. You got many replies that are sensible - now give it up and run the right stuff or go buy a car that runs 87! |
06-21-2013, 08:34 PM | #22 |
1048
Rep 5,660
Well, my cousin finally returned my call. She regularly puts 89 and 87 in her car, regularly as in from the day she got it back in 2010. Admittedly it's an E90 with a I6, and not a turbo 4, which is what my kid has, and I know there has to be some difference between the two engine's tolerance for differing octanes. However, I don't care to read -- here or anywhere else -- about what those differences could be. I just want to know if anyone's actually used 89 or 87 in their car.
She said she can't recall the last time she floored the gas. (I can vouch for this being true; she's drives so much like an old woman that it pains me to ride in the car when she's driving.) She said she hasn't noticed a single thing being wrong with the car and that the car's performance hasn't changed as far as she can tell. Odds are she could burn moonshine in the car and not notice a performance difference. That's about what I expected her to say, and why I posted something here. I know my son drives a bit more assertively than she does and he has a different motor than she does, so I don't want to just assume that her experience will mirror his. I also know my daughter is doing the 93, 89, 93, 89, 93 back and forth thing I suggested to my boy. She's detail oriented enough to keep up with it; he's not, and he and I both know it, which is part of why he asked in the first place. My daughter, however, also has an I6 (2010 E91 328).
Cheers,
