DIY: Cabin Air Filter stripped threads repair
06-20-2013, 06:57 PM | #1 |
34
Rep 288
My cabin air filter threads where stripped so I ordered some Brass Press-Fit Expansion Insert for Plastics from McMaster.
1- Drill the plastic thread with the adequate drill bit size according to whichever insert you ordered. 2- Use some type of glue for plastic to make it stronger. 3- Push/hammer the insert inside the drilled hole. 4- Done. Materials that I used: - Brass Press-Fit Expansion Insert P/N: 94510A050 - M6x1 Screw P/N: 98093A436 - JB Plastic weld Note: I would not recommend getting the same insert I used because I found out they are a little too big. It would have worked better with a smaller one. A better one to use would be: - Brass Press-Fit Expansion Insert P/N: 94510A045 http://www.mcmaster.com/nav/enter.asp?partnum=94510A045 - M5x0.8 screw P/N: 98093A432 http://www.mcmaster.com/nav/enter.asp?partnum=98093A432
Cobb / DCI / VRSF Downpipes / VRSF 7" Intercooler / Walbro LPFP / E85
06-20-2013, 10:37 PM | #7 |
82
Rep 725
nice job seen people just through in bigger screws but I dig this ..very clean
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
06-21-2013, 09:22 AM | #10 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
great idea....someone add this to the DIY section as it can help many people with the same problem.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
06-21-2013, 09:44 AM | #12 |
sudo su -
52
Rep 236
Just another person chiming in that this is an awesome idea, and thanks for posting this! I'm not sure why I never thought about doing this...but it's a great idea. Especially given how many times it seems like I end up taking that damn thing off... I'm missing a couple of bolts on it anyhow.
Now someone just needs to do a writeup on how to DIY fix the little sensor things that are near this ( on either side, I think they're rain sensors?). Mine no longer clip in . The dealer that I always took my car to sure did abuse the engine compartment... |
06-21-2013, 09:58 AM | #15 |
52
Rep 748
Ordered the parts! Thanks!
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
06-21-2013, 10:13 AM | #16 |
26
Rep 497
Mine have been toast for a long time! MUCH appreciated!
08' 335xi 6MT Space Metallic Grey Premium, Nav, Cold weather, Sport Procede 2.5, DCI, Forge DV, PWM, Scoops, KW V1, ETS 5" FMIC, VRSF Downpipes, M3 Skirts |
06-21-2013, 11:07 AM | #17 |
34
Rep 288
You are welcome guys.
I don't know how they could engineer a steel screw to screw on a plastic thread
06-21-2013, 11:26 AM | #18 |
38
Rep 1,079
Most likely just the effects of mass production. Literally every penny saved is considered. Probably had the screw somewhere else in another assembly and was cheaper than bringing in another plastic variant.
06-21-2013, 12:10 PM | #19 |
Power is nothing without control
33
Rep 762
Anyone want to order those from McMaster and split them up for whoever is interested? I don't need a pack of 25 inserts and 100 bolts.
06-21-2013, 01:15 PM | #20 |
42
Rep 659
brilliant solution! i've been pissed off at mine since i keep having to take the cowl on and off.
that's what i had in mind, but probably more economical for someone closer. i'm in okc, OK if anybody wants to do this sharing. |
06-21-2013, 01:38 PM | #21 |
602
Rep 2,703
Drives: 2009 335i - Sport PKG
Nice work
Thanks |
