Need factory default EGS module TRC file for 2009 E90 335i xdrive!
06-14-2013, 06:38 PM | #1 |
Rep 118
I recently flashed my TCU with the Alpina B3 flash and need to get my paddle shifters working. Can anyone share their factory default TRC file for the EGS module for a 2009 E90 335i xdrive with sports package?
Or could I just reflash my transmission back to stock in WinKPF to obtain the factory default EGS module TRC file? Thanks in advance! |
06-16-2013, 02:18 PM | #3 |
Rep 118
When you say I dont need a trc file to code to default, do ypu mean theres a diff procedure? I dont codieren_lesen and sg_codieren? I tried coding in paddles by changing the wert_00 and now I have a malfunction where I can't select a gear.
06-16-2013, 03:35 PM | #4 | |
32
Rep 411
06-16-2013, 05:05 PM | #5 |
Rep 118
Fixed! Everything works esp paddles. Thanks for the responses. In case anyone runs into the same issue, what I did was codieren_lesen the EGS module, execute job, and once it completed once it finished, I immediately switched to sg_codieren and execute job. Once finished, everything went back to default as the members above said.
Side note, I feel better now. I was crazy nervous earlier because I couldn't select a gear due to a malfunction warning. It was a result of trying to change "paddles wert_00" to get my paddles working instead of returning the EGS module back to default. Noob. |
06-16-2013, 06:06 PM | #6 | |
441
Rep 18,331
12-31-2013, 04:39 AM | #7 | |
Bit by Modbug
258
Rep 1,109
Omg thank you OP, had my alpina flash for a couple weeks now and just found the time to do the part 2 a couple hours ago and I got the dreaded gear icon. Was freaking out, tried daten 50.2, daten 49.2 and daten 48.1 and none of them worked. Tried different ediabas and ncsexper versions and nothing worked T_T
So I guess the proper steps is what hectic posted: Quote:
01-06-2014, 08:11 PM | #8 | |
Rep 118
