06-13-2013, 09:24 PM | #1 |
123
Rep 180
335 - where in the RPM band is the engine the strongest
I've got an AT w/ paddles. Yes, I know the computer shifts better than I do but sometimes using the paddles is fun.
Where are the optimal starting and ending points on the tach? ie, if I'm rolling and want to accelerate as fast as possible what RPM do start in and where do I upshift? |
06-13-2013, 09:37 PM | #2 | |
Rep 402
Turbos kick in around around 2500 and the pull is strong from that point on, I usually upshift before 6000. I think the Comp ups at around 5500
Kevin Quote:
06-13-2013, 10:26 PM | #3 |
Rep 64
06-13-2013, 10:36 PM | #4 |
256
Rep 1,297
06-14-2013, 07:41 AM | #5 |
50
Rep 1,730
Most of these high performance FI engines are designed from the factory to protect themselves in the high-end of the RPM band - wastegate bleeds off boost as seen here
source here: http://www.f30post.com/forums/showthread.php?t=652127 If you want to calculate the optimal shift point, you'll map a function of geared torque/power (since different gears will give you different mechanical advantage) vs ground speed. An example will be here: If it turns out that you should always just shift at redline, then you'd see a figure like this: My guess is that in low gears the best solution is to shift at redline while later on it might change since the engine dyno tapers off and the differences in relative mechanical advantage are not that great amongst the higher gears.
UNDRSTR
06-14-2013, 04:59 PM | #6 |
32
Rep 1,285
For greatest acceleration, you want to maximize the area under the torque curve. Typically, this means running the RPMs just passed peak torque and then shifting.
You need to know both the shape of the torque curve and the amount of RPM drop for each shift. Each shift may thus be different. Shifting at redline is often not the fastest. |
