BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > help!after coding cic keep restart
      06-12-2013, 09:03 PM   #1
zd1818
Drives: 335i coupe
Question help!after coding cic keep restart
before the coding of cic everything ok but some functions need to code before use like no sound etc.( I was upgrade from ccc so must need coding). I only done following things.
v47.1 daten I use NCS to change FA production date to #0910 removing old#0906, add$6VA to VO (I already have $609 in VO) write fa to cas and frm. then expertmode coding select cic from ecu list.. After that, pdc sound, safe belt sound and warning sound all came back but the cic screen restarted right after the coding, and it keep restarting again and again. I tried this morning still same. It's quite strange cuz before coding it's all good.
Thanks
      06-13-2013, 01:15 AM   #2
pweber
pweber's Avatar
Germany
37
Drives: M57 330D
Thanks
If it is only coding issue you should remove all VOs you have added and recode your CIC, CAS, NFRM, , just to check will it work.
You also should update your daten and software.
I PM'ed you.
      06-13-2013, 01:28 AM   #3
zd1818
Drives: 335i coupe
Thanks so much. I will try and post update later
      03-02-2023, 06:16 PM   #4
dogrady76
Drives: BMW M3 e92
Hi.
My first time on this board. Did you find a fix for the problem?
I just fitted a cic upgrade to my e92 which had original 2008 CCC. Followed the many online instructions to code it but the CIC just keeps restarting every 10 seconds also with the screen going between the bmw logo and a red screen.
Any help would be great
