Intermittent Wipers / rain sensor disable
06-10-2013, 08:06 PM | #1 |
488
Rep 1,309
Well I've had the car for a bit now, and I'm pretty sure that I don't like automatic wipers.
When it is just misting or drizzling, either they wipe too much or they wipe not enough. When its raining harder, I just end up using the manual low or high speed. I've read that you can code out the rain sensor and be left with a 4-speed adjustable intermittent wiper system (perfect!). Has anyone coded out the rain sensor? Is it just modifying the VO, or is there an option in the module to disable auto wipers? (Yes, I have the cables and yes I've done both types of coding) Thanks! Searches didn't turn up anything useful, so if nobody's done it or posts, I'll just figure it out and post back here. |
06-11-2013, 07:55 PM | #3 | |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
06-11-2013, 08:32 PM | #4 | |
15
Rep 290
+1 |
06-12-2013, 03:09 AM | #5 |
37
Rep 252
INPA:
E90 Karosserie Rain and Light sensor F6 (Activate) F1 (initialize) That's it, now should be much better. I had exactly this same issue and now all works great. |
06-18-2013, 02:55 PM | #6 |
Rep 89
Could you please elaborate on the function of the rain sensor? Wouldn't the rain sensor be set to on from the factory in order for the auto-wipers to work?
06-22-2013, 01:51 PM | #7 | |
52
Rep 1,357
Drives: '08 e92 335i COBB 4.01 Stage 1
More info please. I'm really annoyed with the automatic wipers as I feel they do not wipe enough. Is there any way to make them more or less sensitive? Or, is this a standard reset? If it is a standard reset, then I don't know how it will improve current performance. |
06-24-2013, 10:46 AM | #9 | |
Rep 89
My understanding is, for cars equipped with rain sensors, the sensitivity of the intermittent wipe is adjusted by the wheel on the lever. |
06-24-2013, 11:16 AM | #10 |
488
Rep 1,309
I think ****** is suggesting that we reinitialize the rain sensor, similar to resetting the adaptations on any other sensor in the car.
What I plan to do with coding is to just turn off the damned rain sensor because i could care less about when the car thinks the windshield has water on it behind the mirror, i care about when there's water in front of my eyes. |
06-24-2013, 11:30 AM | #11 | |
Rep 89
Ha ha. True. Last edited by wepio; 06-24-2013 at 11:57 AM.. Reason: I'm an idiot. I just read the manual and ansered my own question. |
06-24-2013, 04:17 PM | #12 |
52
Rep 1,357
That does not work. I think it's there on default for vehicles that don't have a rain sensor. I noticed no difference in sensitivity when adjusting the lever.
06-24-2013, 04:47 PM | #13 |
488
Rep 1,309
the sensitivity adjustment definitely works on my car.
in some conditions, it goes from "definitely not frequent enough" to "almost but not quite frequent enough" in other conditions it goes from "just a little too frequent" to "high speed always on? its like misting, really?" |
07-18-2013, 06:52 PM | #15 |
619
Rep 3,021
Tried this and the intermittent intervals are still pretty ordinary to be honest.
Surely this is something we can code to change? |
